- 24 Mar 2011
- Kent
17cm, the watch is a nice size, not too small or big IMO.
Had a strange thing happen last night with it, hopefully just a one off.
1st night I used sleep for android, 100% battery when I went to bed, 75% when I got up, pretty reasonable.
Last night, it was on 100% again not long before going to bed, nothing running this time and yet when my alarm went off at 5:50 it almost instantly went into power save mode at 9% battery!
You can see the battery was draining overnight. Hopefully just a one off, or the battery calibrating itself?
Today it was on full by about 7:20am and I'm at 58%so plenty to see me through the day .
That would sound like a bug to me if your phone was in DND and you were getting notifications on your watch.
For me, standard is if the watch is connected, that's what vibrates, the phone does nothing... I think?
I'm absolutely fuming with my Galaxy Watch now.
Recently, I've noticed that the Watch is no longer notifying me of anything I'm receiving on my phone. I've reset the watch, checked that the Galaxy Gear app has notification access and the relevant plugins are not set to be battery optimised. Absolutely no difference.
So I randomly decide to test if 'Do Not Disturb' mode on the phone itself would make a different and low and behold, when I turn off 'Do Not Disturb', I then start getting notifications. The weird thing about this is I've always had my phone in DND mode for as long as I can remember, like years and I was 100% definitely receiving notifications on the Watch regardless.
Can anyone else confirm the Watch behaves in this way? I'm using a Pixel 3 on the latest software.
Try this if you haven't got tiles yet, worked for me.
1. Open Settings
2. Select apps and notifications
3. Choose App-info
4. Scroll down and select System Apps
5. Find Wear OS and tap on it
6. Select Force Stop
(7. Go back to the app list)
(8. Find Android System and tap on it)
(9. Select Force Stop)
10. Go to your watch face and wait ~5 minutes.
https://www.reddit.com/r/WearOS/comments/bumakr/a_possible_way_to_get_tiles_quicker/
Got it when I woke up this morning.Anyone received the bloody tiles update on Wear OS yet!?
You mean the orange bit on the right side of the face? It should disappear after you've gone through the tutorial.
