- 26 Aug 2004
- South Wales
We need a price/performance list somehow.. I'd like to see which RAM offers the best performance and when it's pointless to spend more.
Suppose we going to have to wait to see what difference if much or any it makes going to 3600mhz and 4000mhz, big increase in cost.Track down some of the very reasonably priced Crucial Ballistix Sport LT 3000MHz 15-16-16 modules if you are looking at 16GB, these are for the most part Micron E-Die IC's which are going well past the rated speed with tight timings. Currently about £70-75 for a 2x8Gb kit.![]()
Any recommendation for a 32gb kit?
Something smells fishy.
I don’t think I’ve ever paid any attention to the QVL.
I already have a few sets of 4000Mhz GSkill b-die, so I’m set![]()
I have an 8x8GB pack of TridentZ 3733 C17 that works flawlessly in X299. I'd be disappointed if it didn't work well in X570.
The new details are rounded up over at Reddit so let’s take a look at them before heading into details.
4.8GHz is achievable on all cores
~4.4GHz performs similar to a 5Ghz 9900k – in Cinebench
5.0GHz is doable, but it’s a challenge
Overclock for overclocking, Ryzen 3000 is still faster
5GHz boost isn’t infeasible
5Ghz all core is pretty much a no-go.
1.35V for all core 4.5Ghz
Memory is being run very loose and slow to assure the stability for testing
Improvements to memory overclock are going to be 90% down to IMC improvement in the CPU, right?
Rather than the board signalling and bios setting, though they do still play a part.
So I'd expect higher clocking ram on older boards with the new CPUs.
There's talk of a divider/ratio for the MEMCLK and IF this time round.
The gigabyte x570 extreme doesn't use a fan for the PCH - it's entirely passive cooled
https://www.anandtech.com/show/1443...hip-x570-aorus-xtreme-16-phase-for-ryzen-3000
Again proving why the Gigabyte extreme is the best x570 yet
Right you are. Though I'd expect to be able to adjust that in an older board with a bios update.
It popped up on my phone and I had just woke upThat has to be one of the worst articles I have seen yet.
talk about a confused list of "possibilities", they even state it is just a round-up from Reddit
