It's important to know who is disseminating this alleged report and what their backgrounds are. Then we can come to some conclusions as to the credibility of the views that they are then forming from said "report". You're just sucked into the whirlwind of misinformation. You yearn to have found something others haven't. I'm afraid to tell you that you simply lack critical thought and you've been caught up in a propaganda machine that started once Russian military intervention began in Syria. (I can't assume you're part of that machine, that would be too generous of me).
You clearly haven't read the report. Do tell me the alternative interpretation of this...
As I said it's a primary source that anyone can read. It speaks for itself.
"Assessment
32. At this stage the FFM engineering sub-team cannot be certain that the cylinders at either location arrived there as a result of being dropped from an aircraft. The dimensions, characteristics and appearance of the cylinders and the surrounding scene of the incidents, were inconsistent with what would have been expected in the case of either cylinder having been delivered from an aircraft. In each case the alternative hypothesis produced the only plausible explanation for observations at the scene.
33. In summary, observations at the scene of the two locations, together with subsequent analysis, suggest that there is a higher probability that both cylinders were manually placed at those two locations rather than being delivered from aircraft."
But keep going on about a group of British people, not Russians, who have been subjected to a smear campaign for going against the grain if you want.
That you think the 'whirlwind of misinformation' is coming from the anti-war side shows you are deluded. We are on the side of Al Qaeda in Syria yet people pointing out what our gov is doing is wrong are peddling 'misinformation'. Sure.
P.S. Just noticed your 'alleged report' comment. It's genuine, the OPCW have confirmed it.
https://hitchensblog.mailonsunday.co.uk/2019/05/strange-news-from-the-opcw-in-the-hague-.html
But the Mail on Sunday is a hotbed of pro-Russian propaganda I'm sure so you better not read it in case it contaminates your precious bodily fluids.
