MSI B450 Carbon Gaming Pro has better cooling and VRM.
This is the set I got:
https://www.overclockers.co.uk/team...-3200mhz-dual-channel-kit-blac-my-0a2-tg.html
Its £99 now and it has a good chance of being Samsung B-die and even if it isn't will have one of the better alternatives.
It runs at 2933 with a first gen Ryzen but won't do 3200 stable even at the slack default timings.Given their very strong anti rhetoric about their partnership with AMD, I would avoid them.
"Despite AMD's growing stature in the marketplace and MSI's collection of AMD-powered motherboards and video cards, Chiang said that his company is is still reticent to use AMD processors in its systems for three main reasons:
- Prior bad experience: MSI has used AMD processors in its systems before, but apparently had a bad experience. "At that time, their product was not right and their support was not that good," Chiang said. He didn't say which AMD CPU he was referring to, but we know that 2012's MSI GX60 had an AMD A10 chip inside. Our sister site, Laptop Mag, reviewed that laptop at the time and really liked the performance and battery life.
https://www.tomshardware.com/news/msi-ceo-interview-intel-shortage-amd,38473.html
- Relationship with Intel: Chiang told us that, given Intel's strong support during the shortage, it would be awkward to tell Intel if he chose to come out with an AMD-powered product. "It's very hard for us to tell them 'hey, we don't want to use 100 percent Intel,' because they give us very good support," he said. He did not, however, make any claims that Intel had pressured him or the company."
"MSI's M.2 "Heat Shield" Increases SSD Temperature" https://www.gamersnexus.net/guides/2781-msi-m2-heat-shield-increases-temperatures
"MSI (India) Pretty Much Just Called Radeon GPUs "Sub par" https://www.guru3d.com/news-story/msi-pretty-much-just-called-radeon-gpus-sub-par.html
"MSI Betrays AMD's Socket AM4 Longevity Promise: No Zen2 for 300-series?
Greedy motherboard vendors such as MSI want you to buy a new motherboard every two generations of processor for no sound reason at all."
https://www.techpowerup.com/254634/...longevity-promise-no-zen2-for-300-series?cp=9
I bought the same probably at the same time after seeing a couple of reviews saying it will probably be B die but my set turned out to be HynixIt runs at 2933 with a first gen Ryzen but won't do 3200 stable even at the slack default timings.
Most probably your 1st gen holding back your ram. My Ripjaw V 3200 CL16 won't run DOCP on 1st gen but it can on my 2nd gen using same motherboard. It can even oc to 3466 CL16.
What's the performance difference like between 3200 and 3466,?
Might not support the demands 16c needs to operate (power, vrms, temps)
Indeed.AMD CPUs were ****.
MSI's motherboards have been miles ahead of their competitors for AM4.
MSI have already released BIOS updates on their 3xx boards for Ryzen 3.
When benchmarks show an appreciable difference between even 3200 CL16 and 3200 CL14 I can understand the fascination. I do wonder what percentage of 3200 CL16 sticks can be "overclocked" to CL14 though...if it's a lot, then buying the much more expensive set with tighter timings would be pointless.The B-Die obsession on this forum is craaaaazy. It's just not THAT important. I guess whatever sells expensive sticks of RAM...
Indeed.
AMD CPUs were ****.
E3 in 5 days. Hopefully then we will find out which Zen2 chips are fastest for gaming.
I've said it before, I'll say it again. My money is firmly on the 3800x being the fastest in gaming. And there will be some salty gamers out there who wanted the 12 or 16 core. (Also my money is on the 16 core not making an appearance till Zen3)
I think single chiplet will beat two chiplets all the time in games.Almost entirely dependent on binning. Also some games will scale beyond 8 cores.
That will largely depends on how AMD have setup the L3 cache, if each chiplet can share it's cache with the other that will give it a huge advantage over a single chiplet design.I think single chiplet will beat two chiplets all the time in games.
