AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
18 Oct 2002
West Midlands
But as Mr Potato said, that wasn't the case with Ryzen 1 or 2. The problem is Ryzen overclocking has so far been voltage limited rather than temperature limited. If it was temperature limited, one could argue that fewer cores = less heat = more headroom, but the voltage wall is the real problem. Zen 2 might change that but we don't know yet.
Zen/+ had a single large die, are you getting CCX's and chiplets confused. 7nm is more dense so the more active cores in the same area = more heat in that smaller surface area.
21 Jan 2016
13 Mar 2003
location,location
Most probably your 1st gen holding back your ram. My Ripjaw V 3200 CL16 won't run DOCP on 1st gen but it can on my 2nd gen using same motherboard. It can even oc to 3466 CL16.
My current cpu was just a placeholder with the intention of upgrading to either a 2600 or gen 3 and hopefully I should be able to get at least 3200 with a newer chip. I was just pointing out that recommending that ram kit as being 'probably' B die is overly optimistic.
21 Jan 2016
So which of these new chips will be the best value sweet spot for gaming iyo?
I think that really depends on the rest of your setup and how long you expect to keep it.
If you have a middle range GPU and game at greater than 1080p it’s likely any of the processors from 3600 up would result in similar performance so the cheapest one would be best value.
Slightly longer term I think you want to have at least 8 cores to have parity with the new consoles as games will start to be coded to make the most of them and less than 8 might leave you short.
So I would personally say for the medium term, unless you have a higher end GPU or game at 1080p or less with high frame rate targets the 3800 is probably going to be the best value buy for gaming in my personal opinion.
We will have to wait and see how the benchmarks come out though before drawing any firm conclusions.
6 Aug 2009
Just a thought. Can the CPUs decide which are the fastest cores and prioritise those cores when the CPU load uses less than the maximum cores available? i.e 12C part runs an 8C workload, the CPU pushes the work to the fastest 8 cores leaving the weakest 4 cores idle
Caporegime
1 Dec 2010
Welling, London
3600/X 6 core 12 thread £200 / £250 = to 8700K
3700X/3800X 8 core 16 thread £330 / £400 = to 9900K (there abouts)
A couple of queries, will all these CPU’s cope easily with multitrack recording and audio editing? You know like Ableton and stuff, including heavy soft synth use.
How much would you expect a 3600X/X570/16GB bundle to come to? About £500?
Caporegime
1 Dec 2010
Welling, London
I currently have a 970, but I want to game at 1440p (4K where possible) and am waiting for the new AMD cards.
I’m not a big overclocker at all, I don’t feel comfortable with it. I’d rather have a CPU thats fast enough at stock rather than risk messing about with an expensive component, just to get another 5fps or so, that I’d barely notice, if at all.
6 Jun 2008
Finland
I don't buy the logic of a 12c dual chiplet overclocking higher than an 8c single chiplet due to only 6cbeing active per chiplet. If that were the case then it should hold true for 6c Zen 2 and 4/6c Zen/Zen+.
Ryzen1/2 are monolithic CPUs.
With six core SKUs being lower in model line up than eight cores, with those eight core models getting better silicon.
And quad cores having the worst silicon.
With problems in getting good clocks out from that originally mobile phone CPU node, AMD could never afford to waste better dies as cheaper SKUs.
Chiplet/MCM design is lot different.
They can literally test dies and measure which cores clock best (already done in current Ryzens) and simply disable worst cores.
High clocking chiplet with one core faulty/bad can be easily used in 12 core Ryzens for getting the best money from it.
3600-models are vulnerable to competition and price pressure from Intel, 3900X lot less.
In case of single chiplet 8 core CPU every core on that chiplet needs to be good.
And number of such dies per wafer is certainly lot smaller.
While those good fully functional chiplets are needed also for EPYCs, which is going to be that "golden eggs laying goose" product for AMD.
Plus possible later release 16 core Ryzen.
Besides silicon quality thermal density is another.
Higher temperature causes already itself higher power consumption, while also likely needing little more volts.
There are simply many variables in it.
But what is certain is AMD trying to get most income per produced silicon.
6 Jun 2008
Finland
Finding out quality of cores is already part of testing and binning for Ryzen 2xxx.
In fact Ryzen Master marks the best per CCX/CPU and the second best core per CCX.
https://download.amd.com/documents/ryzen-master-1.5-quick-reference-guide.pdf
I'm sure CPU uses same data also internally.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
I don't anything about any of that TBH, but the IPC is high so unless there is something about the software that oesn't like the CPU's it should perform the same as Intel equivalents.
3600X £250 + £150 X570 + £90 16GB DDR4 = around £500
19 Feb 2011
There is some absolute drivel in this thread.. £700+ for a competitive AMD System lol....
Just priced up a 2600x, MSI Carbon Pro B450 and 16GB of G-SKill FlareX 3200mhz C14 Ram £433 for the lot.
