So my tent finally arrived, after a year of waiting. It looks awesome and I’m excited to try it out. With all the fancy bits, and how easy it is to put up and down given its size, im quite impressed, but it’s early days
We’re doing a test run locally with electrical hookup, but I’m going to get one of the battery banks off Amazon with a dedicated plug socket that
@Hades suggested, I’ll check the wattage of my Philips unit and give myself some headroom.
Hopefully it works, as the dedicated ones are very expensive, especially the 3 to 5 night variants.
I’ll report back on its efficacy and link it when I’ve finished testing.
EDIT : Hmmmmm, I’ve just looked at those power banks. It states 2-5 hours for a CPAP machine for one with an apparent 40,000mah rating, early double that of the 2 to 5
day version from Eu-Pap at half the capacity. Perhaps it has something to do with stepping up and converting the voltage, then the stepping it down and back to DC on the CPAP adapter.
May end up with an Eu-pap battery after all.
