AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
Caporegime
1 Dec 2010
Welling, London
Looking at the specs, the base speed of the 3800X is just 300mhz higher than the 3700X and the boost speed is just 100mhz more. Same amount of cores/threads and cache.
In real world gaming and casual use, will the difference between the two even be noticeable?
6 Aug 2009
There must be something missing. Will there be head room in overclocking on the 3800X? Less latency for some unknown reason?
24 Feb 2003
Stourport-On-Severn
5 Nov 2010
Hertfordshire
Better silicon in general. Higher boosts likely and better overclock. Just like the previous Zen and Zen+ generations.
18 Oct 2002
West Midlands
Great, watch high speed mem get gouged to ****.
Its already too expensive.
You can easily buy a 3600MHz C16 16GB kit for ~£95, or if you are sensible, just buy some of the Crucial Ballistix 3000MHz C15 16GB ~£65-70 which is Micron E-die and does 3600 and beyond.
RAM prices are no longer high, unless you just buy them from one shop.
