Yeah it will be some update to AVX that has potentially a 40% increase in performance, in normal use ... 4% lol.
By the time this squirts out of intels behind it will be up against zen3, doubt that AMD will be leaving the performance leadership open to an intel comeback next year.
Gonna get a 3800X and sell my 2700X on the MM![]()
Most telling from that image is that Intel still plan on selling quads in 2 years time.
if you are going to expect that IPC uplift on programs we usually use, you are going to be disapointed...
The only thing that I care about is these leaks will give AMD much more initiative to sell Ryzen 3000 cheaper than they plan to.
Because AMD's primary mission and goal is to attract customers. High prices don't attract customers, the opposite, they make the customers angry.
If they accept the prices it wont make them angry forever, it'll be the new normal.
No, because greediness will strike, and if they'd like to sell the 3950X for 700 pounds, next 4950X will be 1050 pounds.
No one guarantees you that you won't fall into a spiral of ever increasing prices.
yeah because half the price of intels equivalent is being greedy, change the record already.
If the competition agrees that direction aswell (as long as both companies aren't communicating that), it's fine
Anyway the 16 core is under half it's sort-of-competition (16-18 core X series), so really depends what you want from it, but it doesn't seem that bad.
They also offer equivalent performance at £100 less, so I'm not sure what your point is.This is not correct - intel has no equivalent in the mainstream, their best proposition is the 8C/16T chip and AMD offers double the specs for 200 pounds more.
X series chips are Threadripper territory.
The point is to raise the baseline, to avoid dual-cores and quad-cores.
The AMD lineup, if this, looks good:
7 1700 8C/16T
7 1700X 8C/16T
7 1800X 8C/16T
7 2700 8C/16T
7 2700X 8C/16T
7 3700X 8C/16T
7 3800X 8C/16T
9 3900X 12C/24T
9 3950X 16C/32T
Stop drinking the blue coolade dude
I dont get why you are always moaning. The 3900x has the same launch price as the 1800x did 2 years agao with the like for like alternate to the 1800x being $100 cheaper. Based on thge history of Ryzen and Threadripper next gen AMD parts of comparable specs will either bye the same price or cheaper.
Money tight after having our 3rd child and I am strongly thinking about buying a amd 2600 cpu solely for bf5 To replace my amd phenom 955 that that has served me very well and just maybe in the future I can upgrade to a newer cpu and keep same mobo ram extra extra
Pretty sure the R in the top left corner represents Radeon.Because most of the people are like this:
And when they buy in the range 100-300, where 84% of the customers are, most often they get non-responsive configurations. Which means that we must push higher specs in the same price brackets and urgently so.
I am tired of fixing or trying to fix sluggish as snails machines which their users/owners can't normally use!
