- 22 Feb 2014
if you have ripped the solder pads off then this would need repairing first before you could reattach the caps.Wow, this is a popular topic. First of all, it's not a joke, I don't have a soldering iron so I glued them on.
Second, it didn't heppen while I took the heatsink off, after I took that off I took off the small length heatsink next to the capacitors but as it's on with a sticky thermal pad it was very tough to get off, I knocked the capacitors and 4 of them came off with it.
I didn't use a new thermal pad as I don't have any. I may of ripped the solder pads off yes, can they be repaired/replaced with a dollop of solder?. I have no idea what temperature the capacitors run at.
They are surface mount (there is not a hole through the board).
normally done with a VERY careful hand and some small piece of copper wire.
if you haven't soldered in 20 years then this is definitely not a job for you to do without a bit of practice on something else first.
.Please. no glue
