I think they should be fairly similar to standard
Its a CBR, so will be a sporty riding position, they are now fitted
My new controls arrived (minus the pull/push throttle):
Here they are fitted:
Pulled all the connectors out, of the plugs, and worked out what was what using a multi-meter, and made new connectors to connect to the main loom:
Took a bit of figuring it out, but got them all sorted, and everything (other than the horn randomly) is working correctly
So I now have a fully working loom/indicators/lights/dials/switches.
Next I needed to do some work on the inside of the fuel tank. I looked into a load of possible treatments, but in the end I decided to buy some powder for making citric acid, so I can make up my own for future use. Much cheaper, and should mean I can make up many batches if needed.
Here was the tank with the first 100g of citric acid:
Water in:
You can see the line where it was cleaning up to:
Yup, its deffo getting better faster with the 300g concentration, I could even see it bubbling away gently and the water was getting filthy:
That was after a few hours, then with the next batch of 300grams and left overnight again:
Looking a bit better, just to dry it next:
Tank is now dry! The internal filter on the tap was knackered, so ordered a new one to replace asap.
As of now, we have a fully working loom, most of the controls, and other bits fitted. I even pumped up the tyres, and they hold air. As for the forks. I have a new lock set on order to replace the ignition/fuel tank lock and rear hatch lock.
Current to do list:
Clean, refit, and bleed the front and rear brakes
Purchase clock/fairing and light front frame
Purchase lights units, fit them!
Buy fairings
I may also need to replace the rear subframe.. its been altered quite a bit, and may not fit the original fairing mounts.
Fit throttle
Fit new lock set
Strip, prep and paint the tank
Fit new fuel tap/internal filter
Fit new in line fuel filter
Drill out 2 broken exhaust studs, and replace/re-tap if needed
Paint exhaust and refit
Check it all starts again
Fit new stator housing gasket (broke the old one when I cleaned the contacts for the ignition timing)
Oil and general service
Test ride it
