Wat. I can't see dust causing that. Most hardware has overheat/over current protection. Dust alone can't cause a PC to catch fire. I've seen PC's 3" deep in a thick layer of dust and swarf being used in workshops and none have ever caught fire.
Well i agree its not dust causing that.
Dust + someone who smokes or vapes, can cause a gross, and very flammable goop to build up inside the PSU etc. PSU overheats, and the goop sets on fire, then it just spreads using dust, hair etc.
Probably will work but are motherboard manufacturers obligated to update the BIOS to accommodate them?if it was they would have law suit on hands.... Kinda sold us AMD as being supported till 2020.
https://hothardware.com/news/amd-confirms-am4-socket-support-future-ryzen-processors-2020
that was Selling point for me. If it was not the deal I would have went with Intel again.
Whilst on this subject anybody know which mobo maker has the best track record for supplying updates for their older eol boards?
Smells and looks like a 9900k at 1.35v 5Ghz.
PSU's have a thermal shutdown. and that one looks fine.
I just thought that looking closely at the pic. Wouldn't be the first time SATA power connector on a HDD burnt out.If you look for it it look's like the fire started at the bottom in the Hard Drive Bay, that's the most fire damaged and the rest of the damage seems to be spread from there.
*throws PC out of the windowScary
*Checks SATA power connectors*
Scary
