Video???Honestly? I'm not really fussed which one I end up doing. I'd like to be able to perform both properly though. Low bar squats look cooler to me for some reason though.![]()
Video???
*chuckles*
Try explaining that to any weightlifter, ever.![]()
I missed where he said he wanted to do the clean and jerk or the snatch. Id imagine oly lifters trained low bar first to get strong in any case.
Edit- just reading into it, maybe they dont after all. hmm interesting.
Q. high bar squat pushes knees more forward putting more strain on the patella tendons. All oly lifters ive seen have short stumpy legs which presumably helps with this. If an individual is long legged is that a reason to avoid high bar?
Thought I'd post my set up at home in the garage.
Just need to increase the light thinking about getting led tube lighting & some motivational posters
Not long finished painting all the bricks and breeze blocks white.
I'm currently doing stronglifts
So here's a video of how I would squat naturally without the bar.
I can see the big butt wink. Also my chest isn't strong but I think that's because I didn't have a bar on my back so wasn't forcing my shoulders back.
Fix me please. Haha.
Thanks so much!
I've saved your reply into my notes and will attempt to go through it on Monday when I squat again. I'll give it a go on Monday.
What do you mean by toes at "five-to-one"?
Think of a clock... left foot at 11; right foot at 1.![]()
Are my toes pointed out too much currently then?Good news, you don't appear to have an overly curved spin at all. Bad news, its not an excuse
Slow down this movement, I understand you were probably rushing as you didn't want to get busted shirtless squatting in the changing rooms, but yeap, slow things down and think about them as you go.
To add to everything that @mrthingyx has said, you also look to have a little bit of APT, I will offer the explanation for this that stuck with me the best. Imagine your hip line is the rim of a bucket that is full with water, currently your hip angle means you are pouring water out of the front of the bucket. As part of your bracing, you need actively level out your hips, in bucket terms, you don't want to be pouring out any water from the front, or back, when you are in the top most position before you squat.
My knee is still shagged and I am not squatting still. Continuing with rest of strong lifts. Any suggestion of other things to add to my programme until I'm squatting again, or just do more of the other lifts?
I'm going to go to docs or physio as it is too long and too painful
Does anyone have any advice for setting the deadlift back down again? Might sound silly but sliding it back down my legs always catches the top of my kneecaps on the way back down because they are quite bony and stick out a bit. Do I need to break at the hips first so the bar passes my knees before I break at the knee?
Thanks
Just had a quick practice with empty bar and even if i keep legs straight its still kinda catching on the top of my kneecap and having to go around it a little. Not sure what i can do about this. Gonna have to lower it more slowly than id like when there is weight on the bar.
