Permabanned
- 23 Apr 2014
- Hertfordshire
CH6 already has bios support for new processors.
ah fair one but just wait for reviews mate. you're on a 2700x, it's not like your sitting on an antiquated system that is in desperation of upgrade. i'm in a simialr position to you albeit i'm only on a 1600 used almost solely for gaming and a bit of streaming/recording game play. i'd rather wait on proper reviews even though i know everything releasing sunday will be an improvement.I just wanted an educated guess, that's literally what I wanted lol
I don't understand how a gamer (plenty on this forum) can order on release day without seeing reviews? We don't know if the 3800x or 3900x is best in gaming? which has lowest latency? which overclocks higher? Is the 3800 faster than the 3900x even (overclocked)?? We just don't know yet. So any "gamers" buying on day 1 I find a bit mental. Just give it 48 hours at least to see the real data,
Don’t get it. If you are on a budget then you want to know the best bang for bucks before you splash your cash. I too find the idea of buying on day 1 without having any reviews at hand a silly thing to do.Budget maybe?
Hahaha, exactly!ah fair one but just wait for reviews mate. you're on a 2700x, it's not like your sitting on an antiquated system that is in desperation of upgrade. i'm in a simialr position to you albeit i'm only on a 1600 used almost solely for gaming and a bit of streaming/recording game play. i'd rather wait on proper reviews even though i know everything releasing sunday will be an improvement.
you gotta calm those upgrade itches - i know it's hard!!![]()
So does C7H but microcode is month old or so....CH6 already has bios support for new processors.
I doubt there is games at the moment that run more than 8 cores since most use 4 now.
I know there is a few like B5 and D2 that use more than four, that is why I said "most". But it is only a handful that are using more than 4, let alone using 12 cores. It is the reason why I personally decided to upgrade my 7700K to the 3800X.Say that to Division 2 & Battlefield 5. Game Devs are utilising cores now more than ever.
Not yet but I fully intend to be in readiness for dropping the new CPU in, the new Ryzen 3000 bios updates have been released and are available on the gigabyte support site.
I dont tend to update the bios unless I have an issue and as my 1600 has been ticking along nicely for a good while I didnt want to tempt fate until i had to![]()
hold on, are you me - i'm confused and a bit scared right now!Hahaha, exactly!
I do a little streaming too but I'm a upgrade addict, help me, help me!
Im trying so hard to not get the 3900x for absolutely no reason other than it has 12 cores... And that's more than the 8 i have. That's it, that's the reason....
So I just wanted to know what others were going to get that isnt so silly
.I know there is a few like B5 and D2 that use more than four, that is why I said "most". But it is only a handful that are using more than 4, let alone using 12 cores. It is the reason why I personally decided to upgrade my 7700K to the 3800X.
Games will be coded for the next gen Consoles. which will have....... 8 cores.Very likely most modern games will use as many cores as available. If they are utilising 4 or 8 they wont just stop at that, they will use all they can.
Well let me ask you guys a quick question (let me know if its against forum rules), how do you think I can get out of a 7700K and a Z270E since I am planning to sell it once I get Zen 2. Depending how much I can maybe go for the 3900X.As the next generation of consoles comes around and game engines are getting updated, 8 cores will be commonplace. If you're planning to upgrade every year or so, doesn't matter. If you want 5+ year life line, 8 cores is a minimum.
Got my X470 Taichi Ultimate today, exciting!! Sticker on it says BIOS version 3.20, released on the same day I bought it (lucky coincidence). Impressive service (not OcUK though as they have no stock).
Quick question... my PSU has 2x 4-pin CPU power connectors. For an AM4 motherboard with 1x 8-pin + 1x 4-pin, should I be plugging both 4-pin connectors into the 8-pin socket, or 1 4-pin connector into the 8-pin socket and the other 4-pin connector into the 4-pin socket?
