I love how it does not have this RGB crap who needs that ?? Not me I got extra fan over my DDR's to keep em at lower tempetature for stability. Fan got me to 3600cl14 on them stableYour not alone I swear by 8 pack ram as well.
Yes we have and it's great!!! Can run high or tight and 64gb also working well... Eff is solid too...@Gibbo Will you have X570 Taichi in stock next week? e.g. Monday/Tuesday
6000+ others swear by the 3200mhz kit alone... Pcb is better design than the rest... We contributed a lot to binning profiles and grade necessary....
Gibbo also contributing to design etc.....joint effort...
I'd guess 3%How many CPUs have allowed say the +200MHz offset to frequency curve?
He has his moments, yes.Is 8 pack decent ?
He has his moments, yes.![]()
.Thanks I understand what you're sayingI am... I am not giving perf data or figures I am saying not much variability so far.
I did a pretty interesting test today 1080p Valley, Heaven and 3d Mark, 2080ti. 3600 at 4.1ghz 3600c16 vs 9900k 4.1ghz, 2 cores disabled and 3600c16.
Ofcourse can't share result yet....
Looks like I may be going 3600x rather than 3900xI am... I am not giving perf data or figures I am saying not much variability so far.
Defo did not try this... I only trust ever what I tried myself...Will the b450 carbon pro be ok with the 16 core 3950x at stock?
Yes the 8 pack ram is indeed decent, Samsung b die and great for both amd and intel motherboard's.
It's MORE than Descent I take 8pack memory over G.Skill ANYDAY I'm on 3rd Team group Bdie memory kit all ware fantastic clockers![]()
It's a general gaming IPC test most end users just use xmp.
Otherwise you can say on Intel why not run 4133c12....
Just something general was chosen.
Oh ffs don't be silly. 3600 Cas14 is fairly easy on Ryzen+, should be a cakewalk on Ryzen 2 and should be on Intel as well. 4133c12 is only possible on Intel if the ram is under LN2, you know that as well as i do.........................so why even mention it if it was just a "gaming IPC test" ?
That's definitely uncertain.Will the b450 carbon pro be ok with the 16 core 3950x at stock?
Too bad there aren't motherboards with same "screw useless RGB and plastic garbage" design philosophy...6000+ others swear by the 3200mhz kit alone... Pcb is better design than the rest... We contributed a lot to binning profiles and grade of ic necessary.... And are still doing so always to improve...
3600 sticks I tried are all 4000c18 on x570... Although better run 3600c14.
3600 is far from easy for 99.9% of users.![]()
