- 21 Sep 2018
I was about to get 9900k, but them thought about these extras..... but i am lucky work is paying for my new purchase..... whats best ram to go for if wanting 32GB of Ram, motherboard Gigabyte master X570, cpu 3900x....What if you like to run a twitch stream and a load of browser tabs in the background. 5% gaming performance loss for a ton more multitasking at a lower price and power consumption makes the 3900x the real no brainer.
Having discord alone running in backgroud knocks down FPS while gaming.....He said Gaming dear boy.
Oh well amd...maybe next time![]()
I've priced up a new bare-bones build and it's £1,032! 3900x, Asus Prime, 16GB 8Pac 3600 RAM, £130 1tb NVMe SSD and £50 500GB SATA SSD. When I bought my then the-bees-knees 4770K kit it was only £650PCs have got so bloomin' expensive. I can wait for B550s (hopefully)...
Blown away by the 3700x and 3900X tbh. What AMD have achieved in a couple of years with Ryzen is amazing.
Tested with 3600mhz ram on both platforms.
I noticed a 2%-4% drop in FPS, also same percentage drop cinebench R15 and R20 on a 9900k.....Your PC must be playing up in that case. I used to run discord(now left) with no ill affects while gaming.
Although my 9700K is running at 5.2 while gaming![]()
A lot of game engines fall apart at very high frame rates.
Both was fine. I would run 2x16 though I think 3200mhz. Eff dropped with 4 dimms.
Not at all. In a year it probably falls behind. As soon as PS5 / XBN are out, it's likely curtains. It will be like how Intel fared vs Ryzen 1, but worse.
Plus you can expect more security related performance downgrades.
Plus, most of the reviews you're seeing do not have results for the Intel chips on patched W10 / firmware ...
Plus, you'll actually be able to upgrade to Ryzen 4.
