I don't get it, how can professional reviewers not be on the ball with this? If I was doing a review, the first thing I'd check is that EVERYTHING was up to date (unless there was a specific reason not to, e.g. incompatible software, or a specific BIOS I've been told to use) and then list down EVERYTHING I am using: hardware, BIOS settings, software versions, etc. That way at least if I did something dumb/wrong, people could tell me about it immediately.Anandtech also apparently reviewed not using the latest windows build, which means features like fast time from low clocks to idle aren't enabled along with the newer scheduler. As with most releases some fairly lame stuff going on that would never be gotten away with if an Intel chip was launching.
I suppose it's because they want to do apples-to-apples comparisons without having to rerun older tests, but I'd much prefer reviewers do a smaller subset of actual up-to-date, relevant tests, than a load of dodgy ones!
