- 21 Sep 2018
Nothing negative, just very little gain. A 1:1 ratio is ideal, most CPU won't do more than 1800MHz FCLK
Thank you.
DPD say my 3900x and Aorus Ultra isn't due until 12ish
Not working today. Case is stripped with PSU installed waiting for motherboard, even checked the standoffs are in right place. Windows 10 & BIOS USB sticks ready to go.
As I understand it a Windows 10 update a while ago addressed whatever shortcomings within Windows that made the Ryzen balanced plan necessary (disable core parking), so it has been superfluous for a while.As of the last two chipset drivers there is no more Ryzen Balanced plan included.
Looks like my X470 Crosshair Hero VII has a 32MB EEPROM (256Mb)What's the size of motherboard's ROM? That will determine if it can store all the bells and whistles. I know my B350F Strix can't.
just waiting for my 3800X to pitch up.DPD say my 3900x and Aorus Ultra isn't due until 12ish
I wouldn't call advertising a cpu with a max boost frequency that can't be reached in any configuration "working as intended". I would understand if that max boost could be reached only on high end x570 at temperatures under 70C etc. But testers literally have never seen clocks reaching boost speed at any load.
Stop putting 4.6GHz label on 3900X then. Overclock is overclock, but stock boost must work
On b350 board atm, pbo setting appeared long time ago, first it was just 1 line in bios settings, now the most recent bios got a lot, stages, how far u wanna go +MHz - you name it.But to be honest never understood ppl excitement with pbo, does next to nothing on my pc (hardly keeps all core above 4 GHz with vcore going north of 1.45v on noctua d15s) when you can just change multiplier to 42, ad + 0.2 v offset,keeping llc to medium - it keeps 4.2 all core under load, never goes beyond 1.42v and does downclock itself to around 2.1 GHz under low load.I notice that B350 have no PBO or Precision boost, am I missing out?
It’s not a race lol!DPD say my 3900x and Aorus Ultra isn't due until 12ish
Looks like my X470 Crosshair Hero VII has a 32MB EEPROM (256Mb)just waiting for my 3800X to pitch up.
I have already said this is not all working correctly at the moment. Ofcourse it will be fixed with time so no need to worry.Except some reviewers are hitting 4.6. This guy had issues with the newer Agesa and regressing to 1002 got him 4.6 boost, see the hwinfo shots.
https://www.xanxogaming.com/reviews...w-english-dethroning-the-intel-core-i9-9900k/
Is there a combination of issues with mobo manufacturers / Agesa and chipset drivers that's stopping this rather than the actual cpu. Not need aware of issues with prev gen Ryzens not hitting advertised boosts ?
Amd need to chip in.
my 3900x and asus formula board are due between 12:39 - 13:39 same as others got a tonne of work to tear down my loop and then the old stuff out, plus a really good clean of the case and rads, very busy day ahead for me and most ppl who are upgrading.
From 1 side envy you both for putting whole new and shinny in, from the other going to do 1600->2600x->3700x feels really good too.Mines a new loop so nothing to tear down thankfully. But it won't be under water for a couple of weeks, will use the stock cooler to make sure all is OK.
MEG X570 GODLIKE (AMD AM4) DDR4 X570 Chipset EATX Motherboard
- Socket AM4,3rd Gen AMD Ryzen™,X570 Chipset,up to 128GB DDR4,3xPCIe 4.0
- 3xM.2 Slots
- 3x USB 3.2 Gen2,7.1-Channel High Definition Audio,Supports Wi-Fi 802.11 a/b/g/n/ac/ax,Supports Bluetooth® 5
- compare
- add to wishlist
Review this product
5 In stock Order within 6 hours for delivery on Wednesday, 10th July 2
£749.99 *
Any word on the Gigabyte Aorus Extreme x570 boards?
