Default it's toasty, I'm trying 4.1GHz all core and playing with voltages, I can't get this thing to work stable over 4.1GHz all core. trying for 1.35Vso are people manually changing voltages right now? or are the default auto voltages safe?
Not sure about all board manufacturers but Jayztwocents has just posted an overclocking discussion of the 3900x and the stock voltages the Asus Crosshair board tried to set were very high, e.g. 1.47 vcore, resulting in 40°c idle, and a memory voltage of 1.48![]()
It is a massive improvement, I'd like to see more evidence and my 5960X scores 53.7 on that same benchmark so finally Zen 2 is faster in Arma 3
five years later by 6% or so. I'm pleased for that result as it means AMD have caught Haswell and are likely pushing past Skylake now/soon.
I'd be buying one if I wasn't on 8 cores already.
The test was also using a Vega64 too.
Arma is almost entirely CPU bottlenecked in my experience, that and server performance.
DID YOU KNOW? The new version of AMD Ryzen Master can show you core behavior that other tools can't or don't! Examples include: cc6 sleeping cores, sub-2200MHz idle cores, sub-1V idle voltages, fastest CPU physical core, your motherboard's VRM capacity, and more.
Any chance you can run the benchmark if you have the game??
It is this benchmark:
https://steamcommunity.com/sharedfiles/filedetails/?id=375092418
For people concerned about idle voltages have a read here of AMD Robert's explanations.
https://www.reddit.com/r/Amd/comments/cbbfce/3900x_being_overvolted_on_amd_ryzen_power_plans/
In short use the AMD Windows Power Plan and don't worry about it.
Which is no where near as intensive as a Prime torture.
Maybe, just maybe, AMD have got better things to do with their time than optimise for one **** game that you play...? You know, its not like Intel performs that much better at it either, so have they had their fingers up their butts ever since because they've failed to further optimise for the same **** game...?I'm not denying the game engine is archaic, I'm not disputing that things could be different however that doesn't account for AMD CPUs being seemingly unable to perform in this game until now. All the AI is on pretty much a single thread and the core game engine dates from before multi-core CPUs nearly 20 years ago. I'd have thought that was plenty of time for AMD and if the optimisation could be done better by a primary school pupil don't you imagine it would have been done by now for the price of a couple of cans of pop or McDonald's?
If I was doing productivity work, video editing etc I'd buy Zen 2 3900X or 3800X but I'm not. Even Steve at gamers Nexus said the same, buy Zen if you use your PC for work (content creation etc) and gaming it will be OK but if it's ONLY for gaming then 9900K is still the way to go.
If 3800X/3900X were maintaining 4.8Ghz with 2 or 3 cores consistently I'd buy 3900X tomorrow but the clockspeed deficit and failure to maintain advertised clocks precludes that.
