Does the "sweet spot" for RAM at 3600MHz still apply to X470/B450 boards? Or will the old recommended 3200MHz still apply? When using a 3700x
Now I say MSI here, but this will not be specific towards MSI as all manufacturers have to deal with it. Remember a while ago when we mentioned that Ryzen 3000 procs might not be supported on Series 300 and 400 motherboards due to a too small BIOS storage size?
Well, here's the thing, quickly after that discussion surfaced, AMD and the motherboard manufacturers swiftly declared Ryzen 3000 support.
Here's the thing (2), the old BIOS EPROM sizes are 16MB. You can only store that much data on it. Over the years more and more procs and memory has been added and at one point, it's stuffed. You have to say that this problem is more apparent for AMD as they have a ******** of processors for socket AM4, and that is now working against them.The X570 motherboards all have a 32MB BIOS EPROM to store data, so that's save as it's doubled up right?
MSI now has explained on their website how they will bring Ryzen 3000 support towards say certain Series 300 chipsets, simply put .. you can't have it all. So they have removed older (aging) processors from the new firmware and added Ryzen series 3000 processors. Next, to that, a number of features have been scrapped. A-series and Athlon processors from the 28nm Bristol Ridge generation are no longer supported in the firmware. In addition, the possibility for SATA raid has been removed and has been replaced by a worse, but smaller option as well as very slim GUI UEFI interface.
This applies specifically to MSI's boards however other manufacturers also use a 16 MB bios chip, so they will have to make choices as well. All is not a biggy for most people of course.
MSI drops functions from BIOS of AMD's 300 and 400 series motherboards to support Ryzen 3000
https://www.guru3d.com/news_story/m...eries_motherboards_to_support_ryzen_3000.html
The CPUs still supported in the beta BIOS still seem pretty decent to me:Hhhhmmm wondering wether i should buy a MSI B450 I Gaming now
https://www.msi.com/blog/the-latest-bios-for-amd-300-400-series-motherboard
It's like a simple guide on what to do if you've got an AM4 MSI motherboard.So what's the above article all about ?
Not sure, but could well be. In the same article it states the beta BIOS is only "Click BIOS version (GSE Lite) with less graphics and icons than Click BIOS 5", but they may just be doing this to not waste space on unnecessary graphics. I've no idea what features are missing from beta BIOS (if any), but looks like it's just a simplified UI. I think the simpler look actually looks better in the below pic. Not got an MSI motherboard, so can't I comment on how it functions.I thought msi were having issue implementing the bios ?
good news for those who didnt bought b450 motherboards yet new batch will have 32mb rom:
New BIOS device and Lite BIOS
To be honest, it's a price I'm willing to pay. I don't spend enough time in the bios to give two hoots about what it looks like, and it doesn't seem as if there are any major performance related issues, at least none that I really care about.
I've tried that about 10 times I'm afraid:Try clear CMOS and run with memory at stock till another Bios update. Which memory are you using?
