So happy! But so much work between now and getting to use it. It's just taunting me.
That ain't work, that's fun!
Yea im now feeling they were never shipped in the first place, and possibly not even shipped yet. This would not effect every single company for the same 3800x when 3900x and 3700x etc have been received.
Does not make an sense
Edit -
Aslo, They are receiving just "90" 3800's when they have already had over 200 3900's, over 400 3700's with even more 3900 and 3700's coming. Whats so different on the 3800's that make them less available? it all smells very fishy!
IMO is quite simple: they don't know which chiplets to keep for the 3800X and which one to keep for the 3950X, since both need to be slightly better chips than what ends up on 3700X.
3700x up and running in b350, 4.3 with 1.3v, does above 5k in new cinebench already![]()
Thats wrong Question You are asking.... You should ask if it's stable4.3GHz 1.3V solid ALL CORE? Changed any other settings?
yeap, intel burn test stable, docp with 3200c14 didn't wanna start, but as some1 here suggested in few steps (2666,3000,3200) done, all pbo,xfr,oc disabled, offset +0.25v 4.4 GHz atm , testing4.3GHz 1.3V solid ALL CORE? Changed any other settings?
p.s: either stock voltage or offset is different from 2600x, cause b4 offset of 0.2v would be over 1.4v , but it is 1.395v under cinebench run with +0.25v
U joking right? No way I would fry and degrade "my precious" with that archaic "thing"Try Prime 95.
U joking right? No way I would fry and degrade "my precious" with that archaic "thing"![]()
ran a system for ages that wasn't prime stable but could do every other benchmark known to man and play any and every game i wanted without issue. prime is fine for a 15 minute quick test then it's on to real world use for meIf you can't prime, I got no timeeeeeeeeeeee.
Anyone know if a 3900X is two 6 core CCXs or an 8 and a 4?
The former
