- 25 Nov 2011
- The KOP
@Panos try pressing ALT +R and they is a Radeon Chill and Antilag section what happens if you enable it from there?
I believe when you launch the game you will hear a noise if it is enabled. You can also check via the Radeon Overlay menu to see if it is enabled.
@shankly1985 also.
In World of Tanks the Gaming Experience tab appears only on fullscreen mode. Not on Windows or Windows Fullscreen.
Pressing the ALT+L doesn't toggle Antilag even if when Gaming Experience tab is open in the overlay (ALT+R).
However going to Gaming Experience tab and activating it manual, while doesn't generate any special sound, seems is ON. And remains ON even when client is closed and open again.
All these with the Vega 64, fully up to date windows 10, having done a purge of previous drivers last night with DDU, and CCleaner afterwards.
FYI Matt, the issues I had with blurring textures (on all DX11 games I play) with 19.6.x drivers, forcing me to roll back to 19.5.1, doesn't exist on the 19.7.1. Good job.
When I have the 5700XT AE, will check if the issue persists in WOT or not.
Ok getting issues with the 19.7.1 driver with the 5700 XT, im using the latest update from windows.
im getting a lot of crashes in game and games that run full screen, well it just doesnt like it at all.
my monitor also has built in speakers and the windows option actually drops randomly from the audio selection.
I have uninstalled via DDU and Ccleaner but the issue still persists, the exact same.
Sometimes I can get into games just fine and these are usually DX 11 titles, sometimes it crashes outright or during gaming and quickly in mind you.
FF14 is best case to use, this game just wont run full screen with this driver and gpu right now, windowed mode actually can work, but still can crash.
Sadly i cant install an older driver as it does not let me via the 5700 XT.
when games run, it actually runs really well.
Also when going into wattman, all options are just removed, it doesnt let you do anything.
So with my new Ryzen build I decided to try the latest Radeon drivers with a fresh Windows 1903 install. Turns out they're still crap. Freesync is completely broken in fullscreen mode when playing Overwatch (monitor is just constantly switching from 57 to 144 Hz and back again), whereas it seemingly works properly in Borderless Windowed mode. Might have to go back to 18.11.2 yet again, sigh.
Hmm, I do have the in-game cap set to 142 ("display based" doesn't work) but I'll try that, thanks.Blizzard has broken FS on Overwatch since January 2018 patch, however there is a trick around to set 142fps cap on Wattman, it works for many.
no no the ingame cap should be 144hz.Hmm, I do have the in-game cap set to 142 ("display based" doesn't work) but I'll try that, thanks.
Thanks, this seems to have fixed Freesync in fullscreen mode. I still have the issue where I have to re-apply my overclock/undervolt every time I reboot though. I really wish there was a way to automate it (e.g. have a script run on startup).no no the ingame cap should be 144hz.
The driver cap should be 142
Thanks, this seems to have fixed Freesync in fullscreen mode. I still have the issue where I have to re-apply my overclock/undervolt every time I reboot though. I really wish there was a way to automate it (e.g. have a script run on startup).![]()
Yes, I have it saved to a file. It's still really annoying to have to open AMD Radeon Settings and go through the options to get to the "load profile" button every single boot though.Hmm, I never had this issue. :/ Have you considered to save the file?
This is a fresh Windows install with a new rig mate.Seriously never had this issue. When was the last time you used DDU?
Disable Windows fast start upThis is a fresh Windows install with a new rig mate.
Honestly I think I'll return my 5700XT as faulty. I can't play any of my games on it. Apex Legends - runs 'fine' without crashing but stutters and freezes periodically. Battlefield V - just exits to desktop randomly.
