AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
TrM
TrM
3 Jul 2019
@Kieran
How can you use Noctua fans in such a nice setup:) with a glass side panel nice case nice cooler the asrock Taichi looks good and so does the gpu then you have those brown and beige fans :)
TrM
TrM
3 Jul 2019
I like them. But yeah if I was to do it again aid go for black or RGB fans. I had them from a previous case that didn't have a window.
I think the fans are still some of the best on the market and I would love to have Noctua fans in my system in in my phanteks elvolve x case no way to hide the brown :) but I do like your build though :)
18 Jun 2018
Was looking at Ryzen chips earlier for a possible Nas build with high core count and it occurred to me that there's rather a large whole in the range when it comes to integrated graphics.
I can only get a quad core Ryzen with integrated graphics opposed to an octo core 9900 from Intel. I know these are meant to be desktop/work station chips but even when you look at TR no integrated graphics for server builds. Is TR also only intended for PC's?
Just seemed a bit of an omission from AMD on this.
This is what you need. AM4 mobo for server environment (and it even has IPMI!)
https://www.asrockrack.com/general/productdetail.asp?Model=X470D4U
Hopefully Supermicro will also be making good server mobo with IPMI for AM4 that can handle 16 cores...
Some Xeon from intel also does not have dedicated graphics.
Permabanned
2 Sep 2017
Lol, someone putting a 1 star review on amazon saying that the 3900x should have been £270 as it’s the 2700X replacement. Think they’ll find that’s the 3700X. 3900 is a whole new Ryzen 9 series.
3900 is not a whole new Ryzen 9, it's just a naming scheme which legalises AMD's infinite greed.
The difference between the 2700X and 3700X is very little - somewhere around 8% in CPU-Z https://www.guru3d.com/articles-pages/amd-ryzen-7-3700x-ryzen-9-3900x-review,11.html and 15% in CB15 https://www.guru3d.com/articles_pages/amd_ryzen_7_3700x_ryzen_9_3900x_review,9.html performance jump and it doesn't warrant to be called a replacement.
This is actually the same level generational improvement as intel's were before 2017 and the original Ryzen launch.
Caporegime
1 Dec 2010
Welling, London
Your opinion means nothing as you are an obvious troll
30 Sep 2008
surrey
Everyone's a comedian! Tell us another.
8 Mar 2019
@Kieran
For a lot of ppl (me included) those brown fans are a mark of quality( not going to buy black noctua's)
Permabanned
12 Sep 2013
Knowhere
:D I’ve been fighting the urge to scratch the upgrade itch since 2pm last Sunday but having seen that a few people genuinely have had loads of issues I think I’ve made the right call for now.
Same here, I did the same with the first gen release too. I got my 1600x 3 or 4 months after release avoiding all the issues, I bought the 2700x on release but that was a mistake as I ended up having to replace my B350 board due to compatibility issues, I'm glad I didn't dive in straight away this time, For now I'll sit back & watch & make an educated purchase once everything's on the table & running well, It may also mean Intel's back to being an option if they get a response out in time, I was initially looking at a 12 or 16 core Ryzen but they look a bit disappointing so if we see Intel come back with a 10nm 10 core cpu range I may opt for that if its gaming prowess outshines everyone including the 9700k & 9900k/ks. My PC's main task is gaming at 3440x1440.
13 Jun 2009
@Kieran
Noctua fans for the win my friend. With the Meshify C DG, all I can see through the window is faint lines of beige fans either side of my CPU cooler. Oh, and a red "UL" glow from my Sapphire Pulse...seriously where the **** am I supposed to put the GPU power cables when they come out the side of the card??
P.S. Yes I need to rotate my CPU fans to get rid of the cable slack, it's cos I added the low noise adapters afterwards.
TrM
TrM
3 Jul 2019
this is the reason why i cant use noctua fans in my system and why i sold all my beige and browns not for performance but They really stick out in my build! PLease ignore the softtubing im having a problem with the gpu fitting block and add to buy a replacment from germany so i can put my hard tubing back in
sorry but to me noctua fans are a no go
