AH AH AH.No high pitch noises that I've heard, other the squeal of pain from the other half when I told her what I spent
Hum thats weird are you on an nvidia or amd gpu ?When I enable Freesync Ultimate Engine when I'm on the desktop screen image breaks up into a garbled mess, interesting if I do it in a game running freesync and toggle it from normal/ultimate it's fine.
 I came from an Acer XR341CK and it's certainly feels a better screen than that, I used to run 3 x Dell 2407s before that and I now realise how much I missed there extra "real estate"
I also used to own a XR341CK.
The contrast is way better on this one without losing on colour reproduction which makes sense since this is a VA panel.
Hdr is pretty good on the screen the backlight dimming is a bit lackluster so you dont have the contrast of a full array local dimming tv but the extended color range and luminosity makes it a really good experience nonetheless.
How can you say Raprorpg, that HDR is pretty good? Many of us are sharing the same bad experience with washed out colors in games in comparison with SDR. Maybe you think some games, where HDR doesn´t need to be activated in Windows. Posts like this are making things worse for us, cause Samsung can think, that HDR is OK and doesn´t give us the Firmware update, which we need asap.
When HDR is really good on your panel, then share your setup/settings please. Thx.
How can I say this well because the experience is good, and you know that you dont need to be so aggressive especially if you end up asking me for something.
But Hey let me humor you.
In order to have a proper hdr signal on a radeon card (cant speak for nvidia as I dont have one) You need to set up the max refresh rate to 100hz in order to enable the 10 bit color depth ( you cannot have real hdr at 8 bit).
If you really want 120hz use chroma sub-sampling in games it wont matter much as long as you don't have a lot of text.
The next step is to get hdr properly set up in games, some like tomb raider will require to have hdr enabled in windows in order to have the option available (this is a pain but it is what it is) other like the division 2, resident evil 2 or ac Odyssey don't look at the windows setting and are able to look at the screen capability directly. If you are on a radeon card try to enable the freesync 2 hdr option when you can as this will improve the latency.
Like I said the experience is not perfect the low number of dimming zones doesn't allow you to get perfect black and very high contrast but the screen in my set up doesn't have any issues with color rendering.
I have a Sony XF9005 and where it wins largely in contrast, I am getting around the same color output.
I was not aggresive, if you feel it so, then I am sorry. I have Nvidia Card, so that´s maybe the difference, or the reason in this case. I have it set it on 100Hz an 10bit and like you said, HDR has to be set properly in game to make it look good. In AC Odyssey it looks +-good, cause there is no need to set it on in Windows. It Looks bad only in games where HDR has to be activated in Windows before start like f.e. Tomb Raider. or Forza Horizon 4. The colours are not so inaccurate, but little bit faded, washed out, not vivid/juicy. When I switch it to SDR, everything becomes much more alive and you see these shiny Qled Colors. It is possible, that the black reproduction affects other colors in HDR, I don´t know, but I have XF9005 too and the colors on TV are much more vibrant as on Samsung CRG9 in HDR, here I am 100% sure. Thank you for your answer.
. . For exemple the latest ratchet and clank on PS4 can look weird in HDR as you would expect just saturated colors everywhere, the game still have them but it is more subtle in its presentation.
