AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
18 Oct 2002
what I am saying is, if you want to go full romo then I would be looking to buy 10 kits of something like this and then sell 9 of them once binned:
G.SKILL F4-3200C14D-16GFX
You don't need to bother with the 4000+ C18/C19 ram kits.
Out of the 10 kits you will probably find two Dimms that do DDR4000-C12-1T. These two DIMMS will probably do 3600-C12-1T when put together, they may not.
My point is, you need to ask yourself, at what stage is enough? At least sticking with the 8 Pack kits keeps you sane, you know they will play nice together and won't break the bank.
Permabanned
23 Apr 2014
Hertfordshire
Have You missed part where I upgraded from Binned 3733 mem kit to binned 4133 8pack ones ?? I highly dubt that Zen2 8pack mem kits will be running super tight timings 3633 at 1.45 - 1.5 volts xmp profile.
I looked around for 3600cl14 kit does not exist. I know That Gskill used to sell 3600cl15@@1.35 sometime ago
https://www.tweaktown.com/reviews/7...6gb-dual-channel-memory-kit-review/index.html
Thats best kit I'w seen but cant buy it anymore :/ those did 3600cl14/13/13/35
Ill try to move to 3600 14/13/13/35 t1 with this kit. got many options to find whats up
GSkill are bringing out the Neo kit CL14 3600.
https://www.guru3d.com/news-story/g...mory-series-for-ryzen-3000-x570-platform.html
Permabanned
15 Oct 2011
Nottingham Carlton
Managed to get my 8Pack RAM to CL14 at 3733Mhz but a friend has tested and found it better to stick with 3600 CL14. Will do some memory testing tonight as once I find the sweet point I'm done at last with my rebuild and can focus on games
Thats why I'm working with 3633 speed. Post some aida numbers interested what You got. I have not started pushing this kit at 1.45 like I plan to :)
Permabanned
15 Oct 2011
Nottingham Carlton
To correct the thread from my earlier post regarding 1.45v.
My ram in my ryzen 2 rig is actually at 1.35v.
It was my b die in my intel rig I put at 1.45v (needed to push it to CL12).
This 3200CL14 8 pack ram has no thermal monitoring tho, so I couldnt monitor the temp effects, it seems tho on hot summer days with it at 1.45v the temp increase is enough to make my 65535 ram refresh cycle timing (trefi) an issue. On one hot day a couple of weeks back I had weird crashes that didnt go away until I rebooted and it probably was due to the ultra aggressive trefi I set, so that will either go down to 32768 or back to what I had before which was 11430 (oc.net suggest 12k as a safe value thats better than stock, 11430 is what I calculated to be jedec spec to match the higher clock speed of the ram so thats probably how they got to 12k). Basically how far trefi can be pushed is linked to the temperature of the ram, as hotter ram will get flipped bits quicker and its the reason why dram has to self refresh. I may also decide to keep 65535 trefi, but just back off the voltage and go back to CL14, as maxed out trefi has decent gains to both bandwidth and latency, whilst CL12 just helps latency.
I just ordered laser termometer so i can check what sort of temps are mem kits running at with my fan lowing at em :)
13 Jun 2009
Did my first proper recording of CPU stats (using HWInfo) during gaming. In a 10 minute Overwatch match, my R7 3700X settled at 4.225-4.25 GHz at 1.37-1.38 V, with temps averaging 65-70 °C. Not bad for stock.
When the game is running but in the menus (so minimal load), all cores are running at 4.325-4.35 GHz. Pretty good considering the max boost clock is 4.4 GHz.
