The mobo led’s go off, but the ram ones stay on all the time.
Yea, i only mentioned it because people were saying your PSU has a problem because of the clicking when powering the system on and off when that's normal for some PSUs.
It's probably been mentioned but have you tried reflashing the BIOS using Q-Flash plus?
Like now fans run at 800rpm for general use, Battlefield is set for 1200rpm as that pins both the GPU and CPU hard, and ofc sets the correct RGB to match
