I am using first and second slot since they seem to be in order from top to bottom.Does anyone have any default fire and forget settings for a 3800x on the X570 Taichi? will be running 3600mhz C16 Trident Z RGB Ram, would like to leave it on PB2 if possible as im not interested in PBO as it sounds like it does sod all anyhow.
Do i need to manually change voltage at all? been reading conflicting reports, some people say yes and some people say it gimps the performance... not sure which to believe.
XMP or dial in manual settings? what kinda voltage for ram if so? mines rated 1.35v for its settings 16-16-16-36 i believe.
From what ive been reading these chips you pretty much put in, fire up and leave everything near as default as possible, other than ram and potentially undervolting.
What slots for my 2 NVME? im guessing top slot and middle slots?
DRAM was set manually to 3600mhz, timings were done alone, and manually set 1.35.
All I did to the CPU was -100mv vcore and LLC level 1
To be honest I haven't changed that so it is on Default, don't know which level it would beBy default is the Precision Boost set to level2 then?
Because you have to use the screw that you removed from the armour itself. To remove the shield you need to remove 3 screws, the top/left screw goes exactly where the first NVME goes.I used the middle NVME slot for my m.2, as the top one had a standoff which none of the screws fitted, whereas the middle one was fine. Not sure what that was all about, but Windows installed without issue, so I guess it doesn't matter?
I don't think it makes a difference though, only the 3rd slot is the one that disables one of the SATA slots as far as I can remember.Doh! Oh well, I'm not doing all that again, it works just fine as is, and I've had enough for one day!![]()
I don't think it makes a difference though, only the 3 slot is the one that disables one of the SATA slots as far as I can remember.
Well once I had installed everything and was ready to boot the PC I noticed I had not fitted the read IO perfectly and was slightly bent. I removed all the board screws with everything installed to fix it lol. I could had left it how it was but I was not going to be able to sleep knowing I left it like that.No harm done then, just me not paying attention. I also missed a single bloody motherboard standoff, and only noticed it once I'd done all the damned cables!![]()
1.10what BIOS version did your Taichi ship with everyone?
I see the BIOS update section of their website is down. not ideal. https://www.asrock.com/support/index.asp?cat=Drivers
I haven't even updated mine yet, and I'm very hesitant to do so, since the only improvement listed by ASRock is system fans! Unless there's other benefits they're not listing which are considered crucial?![]()
