AMD x470, B450 motherboard on zen2
Paulswen posted something about contacting a competitor to OcUK and they said 26th November. I don't know if he was referring to the Tomahawk Max though. I assume so, given the thread title. Unless they completely got the month wrong, and meant July not November. :p
LOL i think he wrote "26th However......." not 26th November......:D
That's the one. I've been keeping an eye that subreddit, but the various threads about people having non-booting systems, have having to disconnect reset switches due to inconsistent booting just puts me off amongst other issues. I'd rather pay £70 more and not have that hassle.
Once I've decided on a mainboard I've still got the decision on what RAM to go for, I'm trying not to complicate further :D
Thanks. The disconnecting reset button is a really strange workaround. Amazing if that truly does work.
I See MSI Have 4 B450 motherboards with the wording MAX on the end with 3000 Series support & updated heatsink,
$189/£150 bit steep, But its good you get 3000 series support out of the box
all 4 boards comparison Link
https://www.msi.com/Motherboard/B450M-MORTAR-MAX/Specification
https://www.msi.com/Motherboard/B450-A-PRO-MAX/Specification
https://www.msi.com/Motherboard/B450-TOMAHAWK-MAX/Specification
https://www.msi.com/Motherboard/B450M-PRO-VDH-MAX/Specification
I Paid £130 for my Asus Prime X470 Pro when first Rel
with ALC 1220 & Purity sound 3 audio & Intel LAN , 6 + 4 true phase
Asus Prime X470-Pro AMD X470 (Socket AM4) DDR4 ATX Motherboard
MB-6C0-AS
Order date:
19 Apr 2018 16:42:00
Delivery method:
DPD Next Day (Mon-Fri)
Delivery costs £0.00
Total order value
£129.95
If you want a ITX motherboard then go for the ASUS ROG STRIX B450-I GAMING £158.99, Same board as x470-i just a different number & cheaper.
Comes with CPU fan header & also 2 x Case fan headers, True 6 + 2 Phase also,
You will need to update the bios to support 3000 series
https://www.asus.com/Motherboards/ROG-STRIX-B450-I-GAMING/ don't think the bios is out yet
The Asus X570 ITX version of this board will be almost same with 6 + 2, but maybe cost over £220
Being ITX They not really done anything Special with the board & PCI-E 4.0 will not matter or super phase & VRM Due to the Size.
Or also good boards
Gigabyte B450-I AORUS PRO WIFI (Socket AM4) Mini-ITX Motherboard £115 Bios is out F40
Asrock B450 Gaming-ITX/AC (Socket AM4) DDR4 Mini-ITX Motherboard £119 Bios is out P330
I Have the ASUS ROG STRIX B450-I GAMING & the Asrock B450 ITX & Asus Prime x470 full ATX
shortly I will be building a new office HTPC for my wife on a thin Silverstone case. It the mini-itx mobo needs to house a 3600, a sata 2.5" ssd, and probably a 1 or 2 TB corsair force nvme, and a radeon fury!
I don't need a fancy mobo. I was thinking along the lines of £115 for something like the B450's below
does anyone have any preference between these two boards or anything similar
Asrock B450 Gaming-ITX/AC" I own with the Ryzen 1700 , great board with no trouble at all
so you will have no trouble with a 3600 :)
Bios update will be needed as you know for 3000 series
Built my 3600 and B450 build last night. Flashed bios using flash button and it worked first time. Really happy it works and massive improvement over my i5 Sandybridge.
I'm currently looking at purchasing a 3700X/3800X CPU but have no idea what motherboard to buy. Ideally I would get a 3900X but feel its too overkill for my needs. Not saying I won't upgrade to a 12C chip in the future though.
As for my motherboard needs/wants, What were regarded as the best X470/B450 motherboards?
My needs are fairly simple:
I've got a vega 56 pulse GPU for now, 1 NVME M.2 Drive, 1 x MX500 SSD, 32GB RAM.
-The best VRM's along with stability and decent Bios
-I don't need RGB but doesn't bother me if it comes with it.
-I don't require Wifi as I'm hard wired now.
-The ability to update Bios via USB would be beneficial but not necessary.
I think that's it.
I don't really have a budget in mind, I initially thought along the lines of ~£250 for a motherboard. What do you all recommend?
Side note: I keep my systems for several years, My current one is around 8 years old.
