- 23 Feb 2009
- Bournemouth
Not really no, RAM speed is about the IMC, not so much the board, i say that because if you get a really crap board you might not get it over 3200Mhz with 3600Mhz capable RAM but that's not what higher end B450 and X470 boards are, Ryzen 1000 and to a lesser extent Ryzen 2000 were limited by their IMC, i'm already getting higher clocks out of My RAM on the same board than i did with the Ryzen 1600, 3133Mhz without trying hard on 3000Mhz RAM, once you go over 3600Mhz Infinity Fabric switches to 1:2 speed anyway, the sweet-spot is 3600 and as long as you have RAM capable of that the B450 Pro Carbon and X470 boards i linked should do that.
This is why i went with the X470 AORUS GAMING 7 WIFI, my tactic of getting a decent motherboard paid off.
No issues setting the ram to run at 3600mhz via xmp ram profile.
If you go with amd make sure your motherboard is decent due to processors and or ram upgrades.
Dan.
