- 6 Dec 2007
- Cambridge
Don't put it to 0%, it's not supposed to be at 0% unless AMD changed it themselves. Just leave it at 90% if it already is at 90%.
Mine was 0% out of the box. I installed the 7/7/2019 driver direct from AMD, if that makes any difference. I've changed minimum to 90% now, but something odd happened there. Did you use the AMD chipset driver or the one from your mobo manufacturer?
