what CPU you paining it with?
Ryzen 5 3600X
Anyone got a good guide on how to undervolt the pulse vega 56 card?
If there are any undervolt/overclock guides that are reliable I'd appreciate it.
Thanks.
Better yet, can anyone just share screenshots of their wattman settings![]()
Thanks. I'm looking to move to and in the near future and the 3600/3600x are my current favouritesRyzen 5 3600X
Can the reference asrock be flashed to a 64 or do I need the sapphire one?
Afaik it depends entirely on having Samsung memory. All reference cards are supposed to be identical. Chance of having Samsung on V56 stock, is somewhere around 10%. NOTE! A lot of people have had issues flashing bios with the Asrock cards, so make of that what you will.
I wouldn't buy the card expecting to be able to flash bios, chances are you're gonna be disappointed.
The last 2 are attempts to post the same picture, uneditable for some reason. There is not much info left anyway, just a custom fan curve and +50% power limit. And as I said it's not a good idea to just copy settings but that's what he asked for. I mean, how high you can get on the HBM def depends on the card and is very variable. Same with p6/7, varies.
What works for one card may not work well for another, even if its exactly there same model.
There are no shortcuts for a properly optimised overclock / undervolt, you have to work through methodically and find what is most effective for your specific card.
The RX 5700 is what, 10% faster than a Vega 56 on average? So it depends if you reckon you can get an AIB RX 5700 for £300ish. Not sure if the RX 5700 has more overclocking headroom though.I'm looking at getting a new GPU after I recently built a whole new rig with a 3700X. I'm patiently waiting for the 5700 after markets but I just saw the Vega 56 Sapphire Pulse for £260. I'm a bit of a noob with all this PC stuff and I've gotten myself confused with all the reading I've been doing. I'm wondering do I really need an after market 5700 or would a cheaper Vega 56 be a decent purchase for someone who only games in 1080 at 60 FPS for games like Total War, Division 2 and Monster Hunter? Any tips greatly appreciated.
I did it, arriving Tuesday. I was so intent on spending the most I could afford I never even considered the monitor I'm using. To think I had an ASUS 2070 Super on order :/ Cheers!For that res/fps, a V56 would be way overkill even. Very good purchase!
