You can have a good look on my Ghetto ddr cooling solution hehehe
But why
There's 2 sites selling it, but yes it's actually a pre-order i guess. The price is quite high compared to cheaper 3200 kits but not as bad as i thought it would be. I don't know how reliable either site is but it looks like one might be a bit better than the other.. (doh)
cause i tend to pump 1.5v in to ddr4 on 24/7 working system?? Do You know how temperature effects memory erors on ryzen ??But why![]()
Thats why i was first on OCN to get 3466cl14 stable on 1700x pass 45c on modules you get errors I'm still waiting for my laster thermometer to check how hot they run with fan nowadaysFair enough, I didn't think there was much value in pushing memory hard enough to need active cooling. It's really rare to see it.
Hit 40C in my garden in Essex, UK. That’s hot enough for this country!
Or is the Gigabyte aorus elite better for the money?
I find it just plain odd that they felt the need to change it at all, how come they didn't change it when AMD pushed out the Ryzen lineup in 2017, or when Intel started doing 18c/36t HEDT CPU's to counter Threadripper, why now?
2% - do you really think that in a line up of modern many core processors that 2% of the total weighting is correct?
Look at Intel's current line-up of CPU's in the 9th Gen listing's only 13 are 4-cores, and 30+ are 6-cores or more, that is over 230% more CPU's with higher core counts. It makes no sense for the 'user' who is using the data, completely ignoring the manufacturer.
Thats what I got for my mate's build quite liked it.Or is the Gigabyte aorus elite better for the money?
I had heard the VRM's were on par with the Taichi.
Depends on what sort of voltage you are using.I know that the Ryzen 3 3200G isn't Zen2 but Zen+.
I've been playing around in Ryzen Master and got it up to 4.1GHz from 3.6Ghz and APU from 1200 to 1625 and everything seems stable at just under 75c using OCCT stress test using stock voltage and a cheap air cooler.
This is my first Ryzen and I've never overclocked one before, do these values seem safe to run at?
They are, the Elite looks great value.
