I think I have this. Fuse 2 goes to the wiper switch, then the motor. The earth on the motor also earths the screenwash pump. I know that earth is good, and I know that at least one power supply wire to the motor is fine as I have 12V there. So I need a switch (either the one already there or another one wiring in as a temporary measure) connecting the supply wire that I know is good and one of the run terminals on the motor. That at least gets them going until I can figure out exactly which bit of wire is busted.
Ask me how I knew, without even checking it, that the fuse was blown.
Because it's French?
I said:...witness the sheer level of hackery that pa and I descend into when refitting a stock Zenith carburettor and realising that the previous owner removed all of the linkage that goes from the accelerator pedal rods to the carb's throttle arm.
Yes that is indeed a flat piece of steel galv-paint sprayed, with a u-bolt clamping it to the accelerator pedal bulkhead rod at one and and a bolt+balljoint at the other attaching it to the Zenith.
La voiture is officially drivable once more.
..... Wipers is a bit stranger but IDK, maybe you'd want to see out of the window when parked.
God bless the French![]()
Subbed !I have a feeling you will be saying this a lot. Question is can it be any worse than the Bentley electricsSubbed !
The Bentley meanwhile wasn't even consistent side-to-side or front-to-back and had completely unlabelled relays with wires heading off deep into the car. Absolutely no way of telling what on Earth they were powering. You'd pull a relay out and nothing obvious would actually change! I never did find out what the one that was twittering behind the dashboard did. Don't suppose I ever will, which is a shame as boy did I lose some sleep and braincells over it...Oh, it's already a thousand times easier to follow than the Bentley was, mainly because this car actually sticks to a sensible colouring scheme for the wiringThe Bentley meanwhile wasn't even consistent side-to-side or front-to-back and had completely unlabelled relays with wires heading off deep into the car. Absolutely no way of telling what on Earth they were powering. You'd pull a relay out and nothing obvious would actually change! I never did find out what the one that was twittering behind the dashboard did. Don't suppose I ever will, which is a shame as boy did I lose some sleep and braincells over it...
Well, my dad has at least driven the car now. Reckons the brakes are an on-off switch (you get used to them, but they're very different) and quickly found out about the lack of synchromesh on 1st - I forgot to warn him about that, but then he daily drove the Landy with no synchro on the first two gears so he ought to cope alright. He hasn't mentioned the steering to me, which suggests that either the extra air I put in the front tyres has lightened the load some...or his shoulders are in good nick at the moment and he didn't find heavy steering an issue!
Theres no brake pedal is there, just a sort of button/dome on the floor.
The DSeseseseses got the button. The ID has a regular-style pedal but connected to (a slightly simpler version of) the high-pressure hydraulics. So you rest your foot on it and it's enough to make the car brake. Push slightly harder and you hear the pump getting ready to really slam the anchors on. And 2-3mm after that it's a bit like you ran into a brick wall
The Bentley brake pedal felt kinda similar, just a bit more mushy.
