I have the following stuff to buy:How close are you to your actual build now @Phate?
- Storage drives
- RAM
- WC Fittings & Tubing
- Coolant
Thats it
CPU is on back order, so hopefully that won't take much longer.
This week the radiators, fans & GPU block are due to arrive. So I will test fit those all into the case along with pump/res and confirm my loop, then get the fittings ordered. I am coming to the UK in 2 weeks so I will get them from OcUK
Storage is pending payday
Counting every mm in this build
There will be a build thread/project log
Should all be complete with up & running the 1st week of Sept, providing my CPU is in hand by then
