Are ocuk getting this anytime soon?
@NikTheSHNIK may know
Says 8 buttons, where is the 8th?
left, right
left thumb x2, right thumb x2
scroll wheel
=7..?
Liking the look of this.
Ordered. Another added to my collection lol. Can't t wait to try it out and see how it compares to the others.
There is Open Razer but it may not support the Viper to start with. But as it has onboard memory you could set it up on a Windows or MacOS machine and it would remember the settings.Are Linux users Screwed?
I heard that the holes are n places you can't see, such as underneath the feet and behind the side grips, etc.How did they manage to get this Razer down to 69g without the silly hex holes?
I just noticed that, I wonder then can you turn off Synapse? It used to have a load of processes running sadly. But you know i really like this mouse and the Huntsman also looks nice. A part of me is sadly thinking that if you had both and it could run minimally then it might be as good as two seperate softwares like i have now Asus and Corsair CUE set to work but they do not startup where as Synapse would always be there on the tray sucking resources.
One thing i will say is when you run a combo of a vendor using both thier KB and Mice the macro combinations are insane because you record keyboard macros and put them on the mouse buttons.
