- 24 Sep 2013
- Exmouth, Devon
Wondered where my Mother's minge got to.
True but it's directly over the RAM so I figured cold air onto it and positive pressure in the case.Not sure the fan setup is right.
Top fan should bean exhaust. Hot air rises.
Rather than one blowing out of the back?Both blowing up should work better.
What is really scary is aviability of 3900xWondered where my Mother's minge got to....Scary
I'm kinda solid at 1.4v 3600mhz 16,15,15,32,50 @4.3ghz 1.35vPassed 16k% Guess Ill try if mining works or reboots with tweeked settings.
@Illuminist any luck with boot up level ??
What kind of stress? I haven't seen over 73ish but the most I hammer it with is OCCT AVX2 or Cinebench.How are the 3700X temps for you guys ? Mine will run in high 70cs under stress. This ok?
I have gpu rad atcing as intake, no where else in case to place it so it's adding heat xD
There must be a small gap at least? Otherwise that's an obvious issue that i don't even see how they could miss, check the temp or put your finger on the heatsink and see how it feels.Mine worked out of the box.
Only design issue I see is that GPU covers the chipset fan completely.
Will do.Yes, Please let us know how it is. Thanks!
I must make sure not to upgrade AGAIN next year. So far I've upgrade every year. Gone are the days where a CPU lasted me 4 years! No point upgrading next year when the big one will be what comes the following year with Zen 4.
You dont want to stop now your on a roll![]()
What is best to use for voltage monitoring.? Cpu-z, ryzen master and hwinfo64 all giving me different values under load...
