- 9 Dec 2015
Cos traditionally the cpu is a little blob of silicon exactly in the centre and every cooler covers the centre just fine. There's no need to have the cooler base covering loads of the IHS if there's nothing under it.
Then AMD decided to put chips all over the place and create drama.
How much it really actually factually matters is all in peoples heads. This is all about differences in temp which will change nothing. But that doesn't stop people or their OCD.
However if making a new model of cpu cooler today (which that isn't) it would be proper design to make the base larger to account for AMDs eccentric chip placement under the IHS.
You make valid points but its not OCD with regards to the convex plates which are designed for centre dies, they are proving to be worse performance from reports on forums ive read (some are). If they are designed to remove heat from the centre then they are no good for Ryzen or atleast far from the best choice and better to look for alternative designs if you haven't bought yet, its good to know this information I think, its early days and everyone is just experimenting. I'm sure if I already had one of them from a previous build I would put up with it but a lot of folk are buying new, may as well look for the best you can.
You are right though, there is probably a degree to how much worse they are, I would like to find out, I bet some are worse than others, The H7 seems particularly bad though from what i've read.
I wouldn't want that sliver of a plate on the Arctic Freezer 34 though either, nor half the folks here I reckon, I don't know exactly I cant find the die picture I had earlier but it doesn't look like it completely covers the corner die, can't be optimal surely?
