- 1 Dec 2015
Hemnes - Because my wife upgraded our whole living room to Ikea Hemnes and this is where my PC will sit
https://www.ikea.com/gb/en/p/hemnes-desk-white-10402412/
Now, most will know I have a Dynamic case and it will fit in the cupboard if i unscrew the door , put it in and reattach . My wife in her glory rejected removing the back panel.... so ... I need something that can sit on the desk, be small and be pretty... hence the Silverstone RVZ 03
And so it begins ! Like most Gamer's I own an ATX sized motherboard, which is/was a flagship model housed in a Large ATX case . Until recently with the release of Gigabytes X570 Aorus ITX board , ITX boards were normally a fraction in terms of VRM and spec's compared to their ATX counterparts. Asus do have the Impact Range but availability and cost put most people off and used cheaper models.
Currently ITX sales are dwarfed by the number of ATX sized boards sold so naturally this is where board vendors would invest the most in . I can understand this but unfortunately ATX cases are all large and space wasted /unused/unwanted .
Currently there are only 2 ATX cases on the market that can give ITX/mATX cases a run for their money in the sizing department;
Thermaltake G3 -23 litres
Sliger Cerberus X - 20 Liters
Both, which can't hold my current GPU- The Aorus RTX 2080 Xtreme . The card is a Triple slot GPU and I thought about moving to an ITX format but only to cases came to mind - Neo G Mini and Sliger 570M . One just didn't do it for me and the other is too expensive due to weak pound .
So, in steps Sliverstones RVZ 03 case !
I worked out, along with some research into HDPlex H2 case that indeed a ATX motherboard can fit into the 'chassis' of the RVZ 03 along with a SFX PSU . And luckily enough, Silverstone Tek has helped out .
Hopefully this will show with a few slight tooling tweaks, they could produce the smallest ATX mass Produced case on the market that can house a Triple slot GPU along side a 240mm AIO/CLC!
Will try to attempt to tidy this post up and get the thread looking a bit more - Pro Mod like when I get the chance but 3rd child is inbound in 7 weeks time!
@Plec @tamzzy , case should be delivered in next few mins!
