Cheers guys - hope all survived mandatory family visits unscathed.
@orbitalwalsh - any updates or have you got your priorities skewed and taking care of your young family at the expense of your mod?
*Hope all is well with the new edition.
Is there an ETA - or is in the lap of the gods?waiting on Waterblock for GPU
lolIf it's perma - have you thought about asking if you can rejoin? I had a brief look through the "Full systems" forum and you post there regularly enough without getting spanked - they may be open to letting you back in if you ask (if they look at your current form for ref). @tamzzy and i could act as guarantors - i.e. he takes the slap while i apologise on your behalf for any future transgressions.![]()
*Also, are you perma- banned from the "New to PC gaming and longest name ever forum" - or is it a longer sabbatical than normal?
Did the water block ever arrive - or is life the main time constraint now?confirmed Gigabyte/aorus cards will have 3+1 year warranty ... via rep.
but dont think i'll upgrade mine this year ...still havent finished the modded case its meant to go into !
*Admit it - your dremel broke due to exceeding its tolerances didn't it.![]()
You really need to stop licking people's eyeballs when you greet them.then getting ill with covid !
Are you reverting back to the original design/cooling concept - i.e. dropping the idea of all under water?will order two sheets of 15mm thick plexi panels soo can add 2x 120mm fans to the rear. allow push pull at the front of the case FOR CPU
