Thanks for the reply. My ticket number is 743100. I drove home from work during my lunch break on Friday to take the screenshots hoping I would get a quick reply, but have had no further reply as of now.Sorry it took so long for you to get a response, do you have the ticket number they passed you. I can chase why this took so long, sorry you had these issues.
All I wanted to know was where to probe with a multimeter to get an accurate reading (and additionally asked if the sensor over-reporting was expected), any return would be via OCUK. I don't want to send it back if its just a reporting issue, especially as there's no stock anywhere, however it does seem increasingly likely its a fault. I've called OCUK and got the RMA authorised, but haven't sent the board back yet.
Since flashing to F4L and taking the screenshots for support I've noticed it gets increasingly hard to post as you increase vDDR from 1.4v upwards without encountering no post, boot loops then auto cmos clear (this is at stock after loading optimised defaults and with memory at 2133mhz auto timings changing nothing except memory voltage). I apparently mistook this for memory instability while trying to set up my memory overclock, whereas it actually happens irrespective of timings or speed. This has pretty much convinced me its faulty now rather than misreporting, my feeling is this indicates vTT out of spec due to vDDR running high.
