@GIGA-Man My X570i overvolts vDDR and it gets worse the higher you go. 1.2v in bios gives 1.228v load, 1.35v in bios gives 1.41v load, 1.41v bios gives 1.488v under load. This is according to software/bios PC Health readings. Is this normal? Im getting much worse memory clocks than my MSI B450i if these readings are correct, its clocking according to the set value not the value im seeing in monitoring. Im on the F3 bios, 3800x and an EVGA 850w G+ PSU. All I have installed is 2x 16gb corsair 3333mhz b-die, an MSI 1080ti GamingX and a corsair 512gb MP510.
Im fine with checking the reading myself if you know where would it be easiest to measure vddr with a multimeter on this board?
