I have it off, and the CPU stays on 4.4Ghz during games, and up to 4.525Mhz during light load.So we should turn off PBO? (It doesn't really do much any way right)
Say what? That sounds weird. I would test it but then how easy is it to force 3.0?From reading around it seems currently yes, also I've been reading some people get higher boost clocks on X570 by forcing PCIe 3.0, not sure what that's about and i would test it but i don't have an X570.
Nice! So many fans!Nice. I benchmarked my new 2080ti and in some benchmarks I get double the score compared to my old 1080ti. This is her final form
Never made a custom loop so I have to keep airflow in check lol. You have 2 rads for the the CPU?Nice! So many fans!
My final form
Yeah one 240 and one 360 all with mag levs. I used to have a radeon 7 water cooled as part of it, so I kept it all for the 3900x it kinda needed it.Never made a custom loop so I have to keep airflow in check lol. You have 2 rads for the the CPU?
The 3900X must be in heaven with those rads for itself lolYeah one 240 and one 360 all with mag levs. I used to have a radeon 7 water cooled as part of it, so I kept it all for the 3900x it kinda needed it.
Probably will water cool this 2080ti at some point too
Thank you sir, I'll have a look to see if anything has changed even though I am very happy with my current settings.DRAM Calculator for Ryzen™ 1.6.1 + MEMbench 0.8
Changelog:
* NEW. Graph of random access to caches and DRAM. Please note , that the testing process may take several minutes.
* NEW. FreezKiller - software that will make your frame rate as smooth as possible without sacrificing performance. New iteration of cleaning Standby caches without jerking. Just click the "Start" button, minimize the application and launch your game.
* NEW. Samsung b-die , Hynix CJR and Micron E-die presets. Particular attention was paid to memory, which is based on Micron E-die chips.
* Updated Memtest mode, the application will automatically configure all the parameters individually for your system in 1 click (just select MEMbench mode -> Memtest).
* Improved support for 4 DIMM's.
* Overclocking potential DRAM received an update (tab "Advanced").
* Correction MEMbench algorithms. In some cases, you will get better results.
* Included libraries for improved compatibility with some versions of Windows.
* Bug fixes.
https://www.computerbase.de/downloads/systemtools/dram-calculator-ryzen/
Test the new option if You can cause I'm rendering 6 hour long project from rave last night cant test anything heheThank you sir, I'll have a look to see if anything has changed even though I am very happy with my current settings.
What’s with mounting the graphics cards at 90 degree angles?
Is that what the cool kids do these days?
Cant beat red. Red is FasterNice! So many fans!
My final form
Hows temps with Block turned around mod ??Soooo much cooler, from 88 down to 79 under full loadCant beat red. Red is FasterHows temps with Block turned around mod ??
Yeah, 90 degree/vertical mounted graphics cards and glass cases with all the LGBTQRGBLED is so in at the moment![]()
But does it cool any more efficiently?But does it cool any more efficiently?
I’d be up for that but if it’s purely cosmetic then I can’t see the point.
Do people actually look at their PC’s when they’re switched on? I must be doing it wrong!
Keeps the GPU heat away from the X570 chipset![]()
Someone could do temps test heheKeeps the GPU heat away from the X570 chipset![]()
