See if I can dremel tomorrow
You'll need to get your wife plus 7 month bump on camera duty - DSLR; set to movie mode. Perhaps, edit out the profanity and severed digits before uploading...
*Pics look great, BTW.
Operation: Square Peg, Round Hole (Determined to get this to stick)
So, did you get chance to scare yourself silly with the cutting disc?
Looking good.
How will you be securing the PSU?
The kettle lead looks like it may get blocked by 24 pin socket/lead - or is that not an issue with the X470?
Yay!!!dremel 4000 !!! start cutting tomorrow. need to upload more pics of 3D space
Would this help with cable management - and possibly help cables to reach? The overhang of the protruding case flipped 90° may work out the same distance, once you take into account the attached cables when orientated in your original position - even allowing for extra width when flipped (if that makes sense).will try rotating it 90 to see how it pans out
Obviously, i'll be devastated but the build design must take precedence.Because i know @Plec loves RGB - might have to get these !! But again, low stock!
https://www.silverstonetek.com/product.php?pid=829&bno=56&tb=101&area=en
The solution/component use looks sleek and the reasoning behind it reads and presents really well. From diagrams looks tight - but possible (the PSU and adapted front panel i'm still a bit fuzzy on - but I'm sure this will sort itself out when you're fully hands on.)will have to sort out shading/rendering but work computer crashes if quality is set any higher . But placed 240 quite high up - doe this to keep ports to the edges, keep VRM cool and then avoid SFX as much as possible . all depends if i go Plexi cover or not
its tight !
Yay!!!
How will you strengthen the panel to support GPU and RAD if not using the Plexi glass?
Sounds like a plan!will measure but might by some fluke off chance be the same height as the Stock bracket- means i could bolt it on . Since Case be be standing tall, I dont have to worry about mavity pulling it towards the motherboard .
I could also trim the width of the Vertical mount and bolt it in a few places to the back of the case Vent where the GPUs heat is exhaust out the back
Progress - and a tidy and potentially sturdy solution. Nice.28/08/19 - GPU placement
Pondering on ideas of how i can hold the GPU in place as well as being flipped so fans are on show... then realised in the current ATX I have used Cooler Masters Vertical GPU mount and its almost perfect
it measures in at 120mm vs cases 105mm so come trimming will be needed . Can mount to top mounting whole that held original GPU bracket and then via the grill vent at the bottom .
Yep- Power cord need to be moved or some fancy cutting
as a note, case will always be in vertical position, so not to fussed with sag onto the mobo
Excellent - project: Square Peg, Round Hole, is literally taking shape!!!>everything's coming up Orbi<
That guy kinda scares me. Am I just being prejudiced?have i got to start imagining you dressed as Mr Tumble (you have kids you know who Justin is)?![]()
I've become immune - he seems to have voiced half our kid's toys in the past. I've been indoctrinated... Plus, he was paired with 'bendy' Sarah Jane in Higgledy House, which eased the pain...Am I just being prejudiced?
