Caporegime
- 8 Jan 2004
- Rutland
AMD don't make 6 core chiplets, they're all 8 core with 2 disabled.
Yeah I dont see the problem?
The 3700X is such good value i went for this over the 3800X. I have a 3900X in my second system.
Yes i still work for AMD, no freebies unfortunately this time.You not work for them anymore? So is there not gonna be any BIOS/chipset enhancements that will leave a gulf of performance difference between the 3700X and the 3800X?
Still can't get my 3800X to draw any more than 60W but it does 4.5+ on 5/8 cores and gaming (PUBG) runs 4.35 on all cores
The 3900x is 2 x 3600 doesn’t have anything to do with the 3800x or 3700x.
The 3950x will use 2 x 8 core chiplets and I’m sure the best will go in those.
Not all 3800x can do that, one of mine didn´t that is why I returned itGot my RAM and IF at 3800 1:1 without any real trouble. Seems rock steady. Think I'll leave it at that.
Really, what reason did you give them? lolNot all 3800x can do that, one of mine didn´t that is why I returned it
Ive seen that before. Why does it say not tested though?Matisse SSE Frequency AVX2 Frequency Voltage % Capable
3700X Not Tested 4.05GHz 1.237V 100%
3700X Not Tested 4.10GHz 1.250V Top 74%
3700X Not Tested 4.15GHz 1.262V Top 21%
3800X Not Tested 4.20GHz 1.275V 100%
3800X Not Tested 4.25GHz 1.287V Top 53%
3800X Not Tested 4.30GHz 1.300V Top 20%
3900X Not Tested 4.00GHz 1.200V 100%
3900X Not Tested 4.05GHz 1.212V Top 87%
3900X Not Tested 4.10GHz 1.225V Top 68%
3900X Not Tested 4.15GHz 1.237V Top 35%
3900X Not Tested 4.20GHz 1.250V Top 6%
3800X looks to be a much better binned 3700x. If you are overclocking then 3800x minimum.
Why don't they test the 3700x at the same voltage as the 3800x? Are they trying to make the difference look bigger than it actually is to drive sales of the more expensive chips?Matisse SSE Frequency AVX2 Frequency Voltage % Capable
My 3800X does 4.325ghz @ 1.325v does that put it in the top 20% of all CPU's or of all 3800X's then, thats 100% stable, tested, tested and tested some more for hours upon end, IBT AVX, Prime95, Realbench, Memtest, AIDA64, ive also topped the Fabric out at 1900mhz, with RAM at 3800mhz.
