This processor has massive width core-wise but a largely derided IPC.
Is the R7 2700 the new FX 8350? Or will it survive and be regarded as a processor that's worthwhile? Will it 'scale' in ways that Bulldozer couldn't?
It is faster than the 1700. Secret is, pair it with 3466 Cl14 using calculator not XMP. It can handle even a 2080.
Here is a 1700 at only 3.8GHz but with tweaked RAM.
ryzen 2700x could handle a 2080 easly even with out 3466 cl14 ram and decent 3200 mhz kitr is fine i had a 2700x with 3200 cl16 kit and my handleed everything i could thrtow at it at 1440 144hz and 4k
LolBoth are 8 cores and both use a socket with A and M in the name. The 8350 and 2700 are exactly the same and should be regarded as rebrands of each other.
In my testing on my system both the 1080ti which was evga black edition which died (brought cheap 120 pounds was a mining card) it just died no output one day so I brought a gigabyte 2080 which was water cooled but th cards was the block for 1080ti was more expensive then the card lol my 2700x handles them perfectly and in no games did my cpu hold me back really. Was a intel cpu quicker in some games yes it was but the 2700x wasn’t to far behind and at 1440p and 4K (monitor and tv ) my system handles it well and at. I point did I feel I was being held back or notice major stuttering or lag.
Here is a link to my results on 3dmark all of them from the last few generationshttps://www.3dmark.com/spy/7321680
The ryzen cpu are still a very good cpu overall tbh
sorry my bad that was a test i did at stock 2080 speeds look at the gpu clock speed lol 1500mhz there abouts
https://www.3dmark.com/compare/spy/7373973/spy/8364856/spy/7321680
just added another of my 2080 runs to compere to yours and that terst i first linked
link to the test on its own https://www.3dmark.com/spy/7373973
