3950x ETA
6 Feb 2019
It'll be better silicon to achieve the clocks and lower power envelope.
If that’s true then hopefully it can hold all core 4.5ghz and 4.7ghz single core or better. If it can do those there is a good chance I’ll get rid of my 8700k for a 3950x. I wanted the 3900x to be good but it was dissapointing in some aspects so let’s see if the 3950x can live up to the hype
22 Nov 2009
Under the hot sun.
IDK why 3900X feels disappointing. I have let the CPU do it's boost, and only OC the ram.
The 1st CCD cores are going all way to 4.55Ghz most of the times when needed and getting to 4.6 or 4.7 has tiny benefits
Whats most important and shows great improvement is overclocking with tight timings at 3866 with 1900 IF.
The difference to 3200C16 and 3866C14 + 1900IF is around 36% more fps. far greater than we can get from 100mhz more.
Caporegime
1 Dec 2010
Welling, London
You honestly can get that much of an FPS boost from just a memory overclock?
1 Feb 2006
From what I have read, 3600Mhz looks to be the sweet spot and its only a tiny amount above 3200Mhz. Hard to believe 3866 is 36% faster than 3200 at any timings.
22 Nov 2009
Under the hot sun.
Yes. Look at Tomb Raider, Hitman, TW Warhammer 2 (and all TW games using that engine will be affected the same)
Others are 10%+
And the article
https://www.gamersnexus.net/guides/3508-ryzen-3000-memory-benchmark-best-ram-fclk-uclock-mclock
6 Feb 2019
Doesn’t clock as high as I had hoped - nor is it as faster I had hoped when compared to my 8700k for games
I’m hopeful the 3950x can get some more fps from higher clocks orbits extra memory cache
1 Dec 2015
@Panos knowing Intel it'll be 5% and they'll rave about it . All Talk from vendors is they know intel have to change pricing . Boards are a heck of a lot cheaper which does help in pricing ! PCIe 4.0 not cheap .
Hopefully things will get interesting . Looking forward to seeing how new intel laptops perform .
It isn't because a 3800x can't do 4.7ghz boost which the 3950x can.
Believe they said 3900x is 3 core CCX and 3950x is 4 core CCX
Caporegime
17 Mar 2012
ARC-L1, Stanton System
I don't know about 36%, seems a lot to me but there is a significant gain to be had from manually tuning the RAM timing with DRam Calculator.
Hardware Unboxed got about +20%
Even i got +15% on the minimums and +10% on the averages vs Toms Hardware testing on a 3600, from thier 82 to my 94, which is the same as a stock 9700K in Far Cry 5. This with the CPU boosting to 4.1Ghz.
I'm only upto 3333MT/s CL16-19-18 on my RAM If some one with 3800MT/s CL14-15-15 of RAM would tune theirs they may see way over 100FPS on the minimums which would be closer to that +36%, maybe...
why are clocks speeds on amd zen 2 so crap? if amd went from 14 nm to 7 nm in last decade why are cpu clock speeds not nearing 10gh by now?
Prabably
*Right thread this time, too many Ryzen threads*
Installed the update, no change...
Just purely out of interest i ran the FarCry 5 benchmark to compare it with Online reviews of my 3600, just to see if my memory overclocking actually makes a difference.
At 720P to make sure the GPU is not the bottleneck, other that that everything is the same as Toms Hardware, and well yes, the difference is huge.... even tho my RAM while better than stock is still not good.
Toms: 82/109
Mine: 94/120 (+15%) on the minimums.
Toms Hardware
https://www.tomshardware.com/reviews/amd-ryzen-5-3600-review,6287-6.html
22 Nov 2009
Under the hot sun.
Is game dependent. Some games the difference is just 10%, on others 20% but there are few having 30% or more. The video & article posted by Gamers Nexus shows those games also, and other games where the difference is slower.
And those with 30%+ are games were current 3900X gets beaten by a margin from the 9900K. The others were the difference on FPS is down to single digits, the RAM has almost minimal to no benefit.
Caporegime
17 Mar 2012
That would make sense given the verity of difference in performance in games between the 3900X and 9900K, according to HUB in 36 games that difference ranges from +4% to the 3900X to +16% to the 9900K and everything inbetween.
Some game are just more susceptible to AMD's Fabric Architecture than others.
I do think its great that if you want to put the time and effort in you can mitigate the performance penalty from the Fabric Architecture by tuning the RAM Timings and Sub-Timings.
Caporegime
17 Mar 2012
On that here is the review, 9900K @ 5Ghz vs 3900X PBO + Auto OC. RTX 2080TI @ 1080P
Farcry New Dawn (Same as Farcry 5) near the bottom.
