AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
29 Jun 2016
why are clocks speeds on amd zen 2 so crap? if amd went from 14 nm to 7 nm in last decade why are cpu clock speeds not nearing 10gh by now?
I would say the clock speeds are excellent. AMD improved IPC enough that the clock speed doesn't need to be extreme - Look here for the efficiency disparity between Intel and AMD processors.
More importantly, the process has little to do with maximum clock speed, particularly in the comparison between 7nm and 12nm/14nm.
The uarch and density elected to be used by AMD is the dominant factor, and they have absolutely smashed it out of the park in terms of die size and performance. Also keep in mind these dies have multiple use cases from personal to enterprise processors, so they are never going to be clock speed optimised.
TrM
TrM
3 Jul 2019
I think the die size actually works against amd here though it’s to small a surface Area for heat to transfer away from the die and not being center of cpu. I believe with socket orientation on the motherboards it’s at the bottom part on the cpu so some water blocks are not as effect as they could be.
I know amd did the io chiplet is older no and it much larger then the dies but these 3000 cpu temps doe suffer from the way they are made atm and I hope that amd change the design for future cpu’s When they die shrink again
What we have to remember is Intel's 14nm+++++++++++++++++++++++++++ is extremely mature.
Broadwell (i7 6800 / 6900 series) was Intel's first 14nm CPU, did they hit 5Ghz? 4.5Ghz at best and like a toaster oven.
7nm is brand new, give it time to mature.
That’s the one thing that will go against amd from there road map they want to jump on the latest nm and process though.
From there road map we see ryzen 4xxx being on 7nm uv process so that would be a maturing but then zen 3 proberly called ryzen 5xxx will be on 5nm and so on. I don’t think we will see maturing from amd like we have from intel.
Not saying that’s a bad thing but amd will allways be at someone’s else process and following what they manufacturer at the time . But Nvidia have shown with there gpu and other company’s have done it’s a very good strategy
25 Sep 2009
Billericay, UK
Intel 10nm CPUs cannot get over 4.5 either, because getting in smaller node doesn't mean better speeds.
There are limitations in relations to physics.
Higher clock speeds are generally harder to achieve now with the smaller process add to that AMD are clearly using the worse silicon for the consumer grade chips so no chance of one hitting 5ghz using normal coolers.
21 May 2018
I think intel process is far better than the one in TSMC, Intel 10nm would equal maybe 5nm of TSMC ?
All mobiles cpus when they shrank improved their speeds
21 Sep 2018
Even a 14nm is struggling to hit 5GHz with a normal cooler. A 360 AIO is not a normal cooler nor is a D15.
22 Nov 2009
Under the hot sun.
that is because of the crappy cheap soldering, people that did delid improved it a lot
Intel doesn't use solder but TIM on the 9900K and most of the X299 platform. (except the top chips).
And is irrelevant what Intel uses because at anything over 8 cores, delided or properly soldered (9000XE series) they hit 90C+ even with dedicated 480mm radiator.
25 Sep 2009
Billericay, UK
10nm is about the same as TSMC 7nm by all accounts. I don't know why you think Intel's is better though Intel can't get any decent consumer grade products from it besides a couple of under powered dual core chips with no onboard graphics, their miles behind TSMC at this time.
31 Dec 2008
9900K IS soldered....
6 Feb 2019
https://www.chiphell.com/thread-2058557-1-1.html
Seems that a beta BIOS is now available for some MSI boards incorporating the new clock speed fixes, and the early reports seem to be that chips are now not only hitting their stated boost clock, but even boosting slightly higher (a couple of different 3800Xs tested there are both hitting 4.55GHz).
And how high does PBO overclocking go now?
Caporegime
17 Mar 2012
ARC-L1, Stanton System
They did something all right... Seem to have introduced more weird clock/performance behaviour along the way.
I read in the Tom's Hardware article what they call thermal boost "issues", a strange and some what hyperbolic thing to say when they also explain this is due to 75 - 80C thermal throttling, this is normal, every CPU has a thermal cap at which they begin to throttle down frequency, these are not "issues" but normal operation of the CPU. This is why, as with any CPU you should make a good choice for your cooling solutions.
