AMD is behind in the laptops chips with 15W-25W.
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-1065G7+@+1.30GHz&id=3466
https://www.cpubenchmark.net/cpu.php?cpu=AMD+Ryzen+5+3500U&id=3421
It may seem so but I am really not. You are free to try with the Ryzen 7 3700U. Its result is ~8000 Passmark points.
I don't have all the existing CPUs in my head - these are the first that I found.
Not sure. With or without the security mitigation?
Is it worth updating to PI 1.0.0.3 ABB?
I would like to know this as well, given that we will have ABBA in around a month or so, is it worth upgrading from AB to ABB ? My system has been solid since AB so I guess I should stick ?
If it's not broke don't fix it. Unless there's a specific fix you need in the current firmware, leave well enough alone.
Tell that to the 3700X I have running 4.5 and 4.4 GHz on the respective CCX's...They're all broke, at least with 3700x, I can't hit 4.4Ghz but I want my CPU to work as intended, newer firmware seems to address this, ABB I guess isn't the one.
If you do manual overclocks with good cooling they run fine![]()
The intel i7 1065g7 costs $426.00, about the same price as a laptop with an r5 3500u processor, AMD haven't brought out any mobile processors with the zen 2 cores yet because the desktop range are so good and such great value that they're using up all the 7nm chiplets they can produce.It may seem so but I am really not. You are free to try with the Ryzen 7 3700U. Its result is ~8000 Passmark points.
Mobile chips are a different beast to desktop because Intel is a step ahead there (10nm Ice Lake on mobile vs 14nm++++ Comet Lake on Desktop), whereas AMD is a step behind (12nm Zen+ on mobile vs 7nm Zen 2 on desktop).AMD is behind in the laptops chips with 15W-25W.
, luckily enough still had a picture with Ryzen mem calc settings for 3444 fast ) big difference noticed so far : temps, never went above 66 C with all testings (noctua D15s ), but still early days; playing with pbo, xfr atm.
, points wise it increased from 4700 stock to 4900 with pbo. Temps went up to 75C . Max volts seen so far 1.44
) , didn't try changing ram timings there.Mobile chips are a different beast to desktop because Intel is a step ahead there (10nm Ice Lake on mobile vs 14nm++++ Comet Lake on Desktop), whereas AMD is a step behind (12nm Zen+ on mobile vs 7nm Zen 2 on desktop).
Also performance numbers are really muddy these days because Intel is going for stupidly low base clocks with high boost clocks. You are going to see massively different performance for a 10 second benchmark versus a 10 minute one, for example. There's a reason the base clock is so low.
