- 1 Mar 2008
- Near Longleat, Raaaar!!
420mm radiator is perfectSilence....
I bet!
More long term, I'll get a 360 with all the snazzy RGB and redo everything with hard tubing. Eventually......
What kit you gone for?Hope not, just about to spank a load of money so I can get it under water! Lol!
Sounds good to me. The EK block is very good. I had a long session on "Control" last night and the peak junction was 60C with a max edge of just 35C.Well, thinking EK block for the vii, probably another EK block for the 1600 unless aquacomputer get their act together and I can get a bracket conversion for my old cuplex kryos (3 months wait.....) and then re use my old DDC pump/res/2x 240 rads/ soft tubing that I had for my i5 2500k. I can make it look pretty later. Oh, and got my eye on a lian li pc-011 dynamic to replace my aged but amazing antec 1200.
Yeah, it's all a matter of finance though. I don't reckon I'd see a massive jump in performance (other than the 1%/0.1% loss we'd discussed previous for the better part of £200 that the 3600 would cost. Where as for the same money, I could give my whole system a much needed overhaul and get both cpu and gpu back under water. Might find I've got an awesome overclocker in my vii if I can keep the temps under controlSounds good to me. The EK block is very good. I had a long session on "Control" last night and the peak junction was 60C with a max edge of just 35C.
I'd consider updating to a 3600 too, I just swapped my brother from a 1700 @ 3.9Ghz to a 3600.
My Ek Block is very good, I used EK on my vega 64 too. I seem to be running at 35c edge 60c junction peak now, is in a large loop though.@Chud_Jenny, @Breezer_, whats the consensus on these waterblocks then? EK block at £125 or Bykski at £109 from the 'Bay.....
Both look great no doubt, is the Bykski block a contender? Ordered most of the stuff now, just can't make my mind up on the block itself...
Ah niceMy Ek Block is very good, I used EK on my vega 64 too. I seem to be running at 35c edge 60c junction peak now, is in a large loop though.
Give sales a ring and they'll sort the price out on the EK block for you as they are reduced on the EK site now.
https://www.ekwb.com/shop/water-blocks/vga-blocks/full-cover-for-amd-radeon/radeon-vii-series
With what voltage, freq and power limit?Sounds good to me. The EK block is very good. I had a long session on "Control" last night and the peak junction was 60C with a max edge of just 35C..
Happy Days! Which version of the block have you gone with?@Chud_Jenny, you are a star! Plus OcUK are amazing as always. EK block and back plate for under a £100Happy days!!
With the current broken drivers I'm running 1800mhz@950mv 1140HBM +0% power.With what voltage, freq and power limit?
Let's compare with my Alphacool eiswolf's AIO. Let's say in 3dmark stress test.
Ok, the non broken driver is 19.7.5.With the current broken drivers I'm running 1800mhz@950mv 1140HBM +0% power.
I'll run a FS Ultra stress test now and post the results for you. I'll take note of ambient temp too.
Driver 19.9.2.Ok, the non broken driver is 19.7.5.
I will post results with the same params in the evening.
And in addition I will post at 1218mv, 2100MHz, +99% power (my max stable without crossing 1218mv)
Good to hear! You'll have to share some pics.Well, she's back up together and running sweet, temps down under load to 64c hot spot, well chuffed.
Time to mess about with fan speeds vs cooling ability and start seeing what clocks I can get
Thanks for the advice all
Overclocking is broken from after 19.7.5. You can change HBM clocks but core clocks just don't apply!Will doStill waiting on a few bit and bobs before its done. Fans etc but really happy with my first effort at both W/Cing a gfx card and hardline tubing!
I'll read back through the posts but whats broken with the drivers? Hopefully nothing too serious... like overclocking support....
