Can be it. HWinfo64 also gave that. Something to do with the way the software works.cpu z most likely giving wrong readings have you checked with something else.
Sending requests, very often, to the cores, causes it to boost, a simplistic way to explain it.
The only app I'm using to check my temperatures/frequencies/voltage is the AMD Ryzen Master.
Few articles around about the issue.
