- 18 May 2010
- London
Thanks for all the help people. The issue is I still remain at an utter loss how to get my ram stable at 3600MHz CL16.
I think the most stable I had it was when I manually entered in only the base timings (16 16 16 16 36 - 1.35v - SOC 1.1v) This remained stable for about a month but then eventually exhibited instability.
I then tried 1.4v all the way to 1.45v on the dram, with 1.45v actually making things more unstable.
But the truth is that 3200MHz CL14 is a smidgen faster than 3600MHz CL16 any way?
3200MHz CL14: 8.75ns
3600MHz CL16: 8.9ns
It doesn't factor in number of modules, sub timing etc. You need something like AIDA64 to properly measure the numbers.
No dual module RAM operated sub 70ns, since the DDR2 era.
I found just the tool!
It shows if accurate that 3600MHz at CL16 is in fact better than 3200MHz at CL14.
Latency is comparable, but bandwidth is 12% higher at 3600MHz CL16.
*Although it comes with a massive disclaimer of inaccuracy.![]()
Actually that sounds about right
As said if you have b-die you should be targeting 3866C16 not 3600C16.
This is probably the wrong thread, but your 8pack kit is pretty impressive and most of the ppl were able to do similar to mine 14-15-14-28 3600, albeit close to 1.5v needed.Anything over 1800MHz FCLK and I get audio corruption in Windows.
I flashed the ABBA bios yesterday for my board and still see only 4.3GHz max boost.
I have PBO turned on as well but set to auto.
How are you testing for max boost?
Lol.I'm not really. I just observe using the windows task manager what speed it reports as I open up the browser and load like 20 pages.
(We should petition OcUK for more emojis!)
Start HWinfo and leave it running in idle. Never heard anyone use windows to monitor anything, if windows was good then there wouldn't be a place for all these apps built and used by pros otherwise they'd all just use windows. You don't even know how often windows polls. HWinfo has been updated with AMD to get the correct polling timings. Hence why all the voltages and boosts etc were not reading right in many popular apps on release.
To be honest if I was on X370 I wouldn't be expecting the results I see on much more advanced power delivery options you see on X570 boards. Not to say you wont, but I wouldn't be expecting the same as latest tech with much more advanced VRM power delivery options if my results were lacking. I have a £160 X570 board and it takes my 3800X to 4.6+ on 5/8 cores. Playing PUBG it does 3.75-4.4 all core. Admittedly the single core boosts are when left idle with stuff running in the background but they do get there as advertised. I think people expect them to get there during testing which is another can of worms all together.
Don't say things like this as your make me want to buy a new mobo! I've already started looking.
But realistically, AM4 has what 1 more iteration left and we will be on a new socket, so not really worth buying a new board.
What board to you have?
I was looking at the Taichi... but if I could get a board at below £200 that essential does the same job that would be perfect. It would probably also sort out the issues I'm having with my ram.
